BMR Suspension Releases New Product - Camber Bolts for 2010+ Camaro and G8 (FC002)
BMR Suspension Releases Camber Bolts for 2008-2009 Pontiac G8 and 2010-2015 Camaro – FC002
Correct rear wheel alignment and add camber adjustability to the rear of your 2010-2015 Chevrolet Camaro or 2008-2009 Pontiac G8 with Camber Bolts from BMR Suspension. The factory camber adjustability can be insufficient once your car is lowered, leading to poor handling and premature tire wear. Fabricated from machined Grade 8 hardware and CNC-laser cut Ľ-inch steel plate, these camber bolts give you 1 degree of additional camber adjustability in the rear of your G8 or Camaro. BMR’s Camber Bolts (FC002) are fully TIG-welded, giving you unrivaled strength and precision. The 1 full additional degree of camber adjustment allows you to correct the rear camber settings when the car is lowered, or to achieve more aggressive alignment setting for autocross or road race applications. Each component of the FC002 assembly is precision machined and fixture welded, giving you the ability to make precise alignment changes. BMR Suspension designed the FC002 Camber Bolts for street performance, drag race, and handling applications. This is perfect for any street or racecar in need of additional rear camber adjustability. BMR Suspension’s FC002 camber bolts are available in a durable black zinc finish for long-lasting good looks. Installation time is about 1 hour. Proudly made in the U.S.A.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
__________________ Allan Miller President BMR Suspension www.bmrsuspension.com (813) 986-9302
