UMI Releases New Product: Upper & Lower Front A-arms for the 70-81 Camaro & Firebird - LS1TECH
New Products Showcase Come inside to see the newest hardware!
Thread Tools Search this Thread
Old 12-20-2016, 09:39 AM   #1
LS1Tech Premium Sponsor
UMI Performance's Avatar
Thumbs up UMI Releases New Product: Upper & Lower Front A-arms for the 70-81 Camaro & Firebird
Upper and Lower Front A-arms for the 1970-1981 Camaro and Firebird
P/N 26xxxx
Prices starting at $449.99
UMI Performance, Inc. is pleased to release our new 2nd Generation F-body upper and lower a-arms as part of the upcoming total product line for this exciting platform. These arms are perfect for the F-body enthusiast seeking to improve the performance and appearance of their front suspension. The current lower a-arms are available in standard spring bucket configuration or UMIís coming soon is an extreme performance coilover-only version. Both styles feature caster relocation of the lower ball joint (2 deg and 4 deg respectively) as well as a variety of ball joints (standard and tall) and bushing configurations (polyurethane or Delrin). The upper a-arms are available in standard or extreme performance adjustable versions. The offset cross shaft standard version adds 3 deg caster and uses smooth UMI Delrin bushings. The extreme performance version is adjustable to easily fine tune caster (5 deg over stock) and add camber without excess shims. They pivot on race quality rod ends and can be loaded with standard or tall ball joints to improve camber gain. Available in UMI red or gloss black powder coat. 100% designed, manufactured and raced with pride in the USA.
WEBSITE LINK HERE
UMI P/N 2651- Polyurethane lower a-arms. 2 degrees of caster.
UMI P/N 2652- Delrin bushing lower a-arms. 2 degrees of caster.
UMI P/N 2653 & 2653-1- Delrin bushing upper a-arms, optional taller ball joints. 4-5 degrees of caster.
UMI P/N 2656 & 2656-1- Adjustable upper a-arms, optional taller ball joints. 5-6 degrees of caster.
UMI P/N 265153- Polyurethane lower bushings, standard ball joints. 6 degrees of caster.
UMI P/N 265253-1- Delrin lower bushings, taller upper ball joints. 6 degrees of caster.
UMI P/N 265256-1- Delrin lower bushings, adjustable upper a-arms, taller upper ball joints. 6-8 degrees of caster.
UMI Performance is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
UMI Release New Product: Upgraded Adj. Front Upper A-arms for the 93-02 GM F-Body UMI Performance Suspension & Brakes 3 02-02-2017 04:02 PM
UMI Releases New Product: Upgraded Adj. Upper Front A-arms for the 93-02 GM F-Body UMI Performance New Products Showcase 0 02-01-2017 10:02 AM
Brand new UMI Chromoly Adj. Upper Front A-arms, 3 Sets, Discounted! UMI Performance Parts Classifieds 4 01-10-2017 10:58 AM
UMI 5-Day Sale! 10% Off & Free Shipping- 11-24 to 11-28 UMI Performance Sponsor Sales & Specials 10 11-25-2016 09:53 AM
UMI Performance New Product- Adjustable Boxed Lower A-arms UMI Performance Suspension & Brakes 2 11-24-2011 01:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
