New Products Showcase Come inside to see the newest hardware!
Remote timing retard adjuster for LNC-2000, 2001 & 2014
Old 02-18-2017, 10:05 PM
ProServ's Avatar
Default Remote timing retard adjuster for LNC-2000, 2001 & 2014
Remote timing retard adjuster for Lingenfelter LPE LNC-2000, LNC-2001 & LNC-2014
Available here in our web store for $44.95.
Also available from our eBay store.
  • Manual timing adjustment interface for use with the Lingenfelter Performance Engineering (LPE) LNC-2000, LNC-2001 & LNC-2014 2-step and timing retard modules for GM Gen III/IV/V V8 engines (including LS1, LS6, LS2, LS3, LS7, LSA, LS9, etc.)
  • Allows the user to manually set the amount of timing retard.
  • Can be remote mounted inside the vehicle to allow easy in vehicle manual changes to the ignition timing
  • Can be used to reduce timing for lower octane fuel, audible knock or other situations
  • Can also be used to simulate MAP sensor and some other 0-5 volt sensor signals
Specifications:
  • 6 ft wiring harness
  • Connects to the MAP sensor connector on the LNC-2000, LNC-2001, LNC-2014 & LNC-002
  • Does not work with LNC-001 or LNC-003 that do not have provisions for a MAP sensor input
  • Module labeled from 0 to 15 to represent from 0 to 15 degrees of timing retard
  • Adjustment module can be mounted with self tapping screws, hook & loop tape or double sided tape (not included)
  • 90 day repair or replacement warranty (buyer responsible for shipping)
NOTE:
  • This is a Product & Service Solutions product and is not made by or associated with Lingenfelter Performance Engineering (LPE).
  • LPE & Lingenfelter Performance Engineering are registered trademarks of LPE Assets LLC
Quick Reply: Remote timing retard adjuster for LNC-2000, 2001 & 2014
