Remote timing retard adjuster for LNC-2000, 2001 & 2014 - LS1TECH
New Products Showcase Come inside to see the newest hardware!
Thread Tools Search this Thread
Old 02-18-2017, 10:05 PM   #1
LS1Tech Sponsor
ProServ's Avatar
Default Remote timing retard adjuster for LNC-2000, 2001 & 2014
Remote timing retard adjuster for Lingenfelter LPE LNC-2000, LNC-2001 & LNC-2014
Available here in our web store for $44.95.
Also available from our eBay store.
  • Manual timing adjustment interface for use with the Lingenfelter Performance Engineering (LPE) LNC-2000, LNC-2001 & LNC-2014 2-step and timing retard modules for GM Gen III/IV/V V8 engines (including LS1, LS6, LS2, LS3, LS7, LSA, LS9, etc.)
  • Allows the user to manually set the amount of timing retard.
  • Can be remote mounted inside the vehicle to allow easy in vehicle manual changes to the ignition timing
  • Can be used to reduce timing for lower octane fuel, audible knock or other situations
  • Can also be used to simulate MAP sensor and some other 0-5 volt sensor signals
Specifications:
  • 6 ft wiring harness
  • Connects to the MAP sensor connector on the LNC-2000, LNC-2001, LNC-2014 & LNC-002
  • Does not work with LNC-001 or LNC-003 that do not have provisions for a MAP sensor input
  • Module labeled from 0 to 15 to represent from 0 to 15 degrees of timing retard
  • Adjustment module can be mounted with self tapping screws, hook & loop tape or double sided tape (not included)
  • 90 day repair or replacement warranty (buyer responsible for shipping)
NOTE:
  • This is a Product & Service Solutions product and is not made by or associated with Lingenfelter Performance Engineering (LPE).
  • LPE & Lingenfelter Performance Engineering are registered trademarks of LPE Assets LLC
ProServ is online now   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Looking for LINGENFELTER LNC 2000 LETHL 03 Parts Classifieds 1 11-21-2015 07:43 AM
Lingenfelter LNC 2000 LETHL 03 Parts Wanted 0 11-18-2015 03:20 AM
LNC-2000 and Leash Single Stage Nitrous Board HELP! slammin86 Nitrous Oxide 1 04-06-2015 02:10 PM
Lingenfelter LNC-2000 2 Step Timing Retard and Launch Control CamaroGuy87132 Parts Classifieds 3 11-25-2012 12:47 PM
Expanded wiring diagrams and instructions for LNC-2000 timing retard controller Jason Haines @ LPE Nitrous Oxide 0 08-20-2012 06:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
