95mm tnt halo or plate?
Old 10-11-2008, 08:01 PM
CraZee ZO6's Avatar
Default 95mm tnt halo or plate?
Might not be able to go direct port and might not even need to only 100-150 shot.
I already have a tnt wet f1 kit on the car but I am upgrading to the 92mm fast with 95mm tb. So my TNT HALO RING will not work I am thinking.. does anyone make a 95mm halo?
Old 10-14-2008, 09:09 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
are you porting the intake to 95mm ???
Old 10-14-2008, 09:46 AM
Nick@HSW's Avatar
Do you have the ring for 78mm throttle body or 90mm?
Nick
Old 10-14-2008, 11:21 AM
Nitro Dave's Nitrous Outlet's Avatar
We may be able to machine out your current ring to fit if there is enough material. Or you could go with one of our plates that will simply bolt in..
Is the intake opening 92 or 95mm? What is the throttle body?
Dave
Old 10-14-2008, 12:39 PM
CraZee ZO6's Avatar
the intake is 92 and will be PORTED OUT TO 95mm and use a 95 rev extreme TB.
the ring I have with my halo kit is a 78mm and there is enough material on it to get it machined to 95mm.
Old 10-15-2008, 07:02 PM
If there is enough material send it to us with your throttle body and we will machine it for you..
Or we can build you a custom plate.. Just finished building a 105mm plate for someone..
Dave
