Nx bottle question
Old 10-14-2008, 03:36 PM
Ruckus46Gt's Avatar
Default Nx bottle question
I got a NX bottle off of someone the other day and picked up bottle nut adaptor off ebay and realized nx uses a 2 piece design. I need to get the plastic washer for it anyone one the size and also does NX use something else instead of it since its a 2 piece design (like rubber or something). Thanks in adfance
Old 10-14-2008, 06:54 PM
myfast70's Avatar
Do you have a picture of the valve? One style uses a teflon washer that rests against the flat face of the threads and the other is a nut & nipple that seals with a pressure fit. If it's just a plastic washer that you need you can go to a welding supply place and pick one up there.
Old 10-14-2008, 09:16 PM
Ruckus46Gt's Avatar
this is the set up it uses on the nx bottle
nipple fits into the bottle nut
Old 10-14-2008, 09:31 PM
Ruckus46Gt's Avatar
this is what i show on nx's site under instructions
Insert the bottle nipple (3) into bottle nut (4) and securely
tighten on the bottle valve. (See Illustration A.)
http://www.nitrousexpress.com/Instructions/stage1.pdf
So maybe no washer?
Old 10-15-2008, 07:22 AM
Ruckus46Gt's Avatar
ttt...
Old 10-15-2008, 10:18 AM
12 Second Truck Club
WJ MARK's Avatar
No washer needed
Old 10-15-2008, 05:10 PM
myfast70's Avatar
Originally Posted by Ruckus46Gt
So maybe no washer?
Correct, no washer. Just crank it down pretty tight and you should be oK!
Old 10-15-2008, 06:31 PM
Nitro Dave's Nitrous Outlet's Avatar
The nipple will seal by compressing into the valve when you tighten the nut..
Dave
