Let's See Some Dyno/Track Numbers from Bolt on Cars with Spray
Old 10-21-2008, 09:37 AM
Golf&GM's Avatar
Default Let's See Some Dyno/Track Numbers from Bolt on Cars with Spray
Just like the title says, post 'em up!
I'm trying to decide whether I want to do a heads and cam car or just do every bolt on I can and spray it. I'm leaning toward the spray because of drivability and I LOVE the 30+ MPG highway I'm getting right now. I don't have a specific goal in mine but I'm hoping some of you bolt on nitrous guys can give me something to for.
EDIT: This maybe should've gone the they Dyno section but I figured I'd get more responses in the Nitrous forum.
Old 10-21-2008, 11:27 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
The number are going to depend on how well the combo is optimized. I have seen almost stock LT1's in the high 10's on nitrous...bolt on only LS1's in the mid 10's and bolt-on nitrous LS1's in the 9's......but on a second note I have seen Heads/Cam/nitrous LS1's in the 12's
If you want to improve your track times without affecting your normal driving....you cannot beat nitrous.
Old 10-21-2008, 11:35 AM
Golf&GM's Avatar
I get what you're saying, I'd just like to see some of the bolt on setups that people are running and what kind of results they're seeing. I won't necessarily be trying to get to 9s but it would be good to see what kind of bolt on setups are putting down what kind of numbers.
Old 10-21-2008, 11:45 AM
streetassasin's Avatar
numbers in sig
Old 10-21-2008, 03:17 PM
bad6as's Avatar
i would say with full bolt ons and on a good tire the car should be in the 12.5 range. now they say 10 hp is .1 off et and add 1 mph. so a 100 shot should knock off around 1 sec
Old 10-21-2008, 04:18 PM
JLD58's Avatar
I just ran my 98 vert with a 100 shot for the first time two weeks ago and ended up with a 13.20 @108 with a 2.0 60 ft. on 275 kumo street tires only spraying from 3k-5.8k from the end of 1st gear to the end of the track, but it still needs a few more runs on it to get the afr and timing right.
Old 10-21-2008, 04:43 PM
Golf&GM's Avatar
^^^ That seems a lot slower than I was expecting with a 100 shot.
So far we've got:
12.39 @ 117
13.20 @ 108
Keep 'em coming, people who are stock w/spray are welcome to post up too.
Old 10-21-2008, 05:12 PM
BAKED's Avatar
My girlfriends car has headers, lid, cutout, 100 shot, and a tune. It is an A4 and it's best pass on motor is 12.56 @ 113 We haven't ever ran it through the 1.4 on the bottle but it ran 7.39 @ 93 in the 1/8th on the jug.
Her car does run very good for no more than is done to it but this should give you an idea.
Old 10-21-2008, 05:15 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
there are quite a few bolt on cars on this list
https://ls1tech.com/forums/nitrous-oxide/835380-stock-cube-nitrous-list.html
Old 10-21-2008, 05:28 PM
krazy4's Avatar
Never ran my car at the track on spray, but with a lid, maf, cutout and 120 shot I put down 478whp. Was a pretty fast car on the street though. Made 354whp on motor. Stock manifolds and cats.
Ran 8.2 on motor in the 1/8 mile with a 1.9 60ft. Could have gone 7.9 with a 1.6-1.7 60ft.
My next car is going to be a stalled auto, big tire, bolt-ons and a 120 shot.
Aiming for low, low 7s.
Old 10-21-2008, 05:47 PM
SuperSlow02's Avatar
Numbers are in sig....good for mid 11s
one of my friends trapped 102mph in the 8th with bolt ons and a shot
Old 10-21-2008, 06:50 PM
Cape T/A's Avatar
Weak^
Old 10-21-2008, 07:07 PM
ballerchris510's Avatar
what shot did u use to get the time on your sig also what are your on/off spray 60foots..... trying to compare to mine n/a did a 8.4@86 with a 2.2 60foot. and puting in a 100 shot this week (ordered it getting here on thurs)....
Old 10-21-2008, 07:11 PM
navyblueSS's Avatar
When my car was bolt ons only with a 100 dry shot it went 11.34 @ 120 on 17in. BFG DRs, Yank SS3600 stall, and stock 3.23 gears.
Old 10-21-2008, 07:44 PM
150 shot off the line
Old 10-21-2008, 09:35 PM
Duffster's Avatar
12.37 'alot-of-boltons' @113 (1.87)
12.16 25-shot (testing the waters) @ 116 (1.84)
Old 10-21-2008, 10:16 PM
MYSTIC-1SC's Avatar
i've ran 7.23 or 7.22 at 102 with mods in my sig. I still have factory 2.73s. I believe the car has quite a bit more left in it if i could actually remove some more of my launch delay, oh well time to get some different tires and let her rip. And superslow your times should be good for low 11s I know mine are.
Golf&GM's Avatar
Thanks guys, these times are getting me looking around the classified section
96 MPH for the 1/8 is stout, but 102??? I'm guessing it's a 200 shot + weight reduction?
Old 10-21-2008, 10:18 PM
MYSTIC-1SC's Avatar
no mods in sig
Old 10-21-2008, 10:26 PM
Golf&GM's Avatar
Yea, looks like we posted at about the same time, didn't see it before it was too late. That's an insane 1/8 trap, especially for a stock head/cam/weight auto car. A lot of 600 bikes trap close to or right under 100 MPH at a track around me. Ever ran it through the 1/4?
Quick Reply: Let's See Some Dyno/Track Numbers from Bolt on Cars with Spray
