Spraying out of the hole with a M6...
Thats what a window switch is for. Set it at 3k and even if you drop down in rpms below that it will turn the system off till you get to 3k or more. If you leave hard enough that shouldnt even be a problem
Its going to take some time to get used to it! If you have the right parts you will still find a weak point with a 6 speed. The technique that i have heard many times about running a 6 speed car is don't just drop the clutch. Put tension on all the drivetrain or find the point in your clutch were you feel the car just starting to move ever so slightly hold the clutch a little off that. Rev your car to the rpm you want and dump it from that point. I have heard that its less of a shock on the drivetrain, but still will allow you to come out of the hole hard!
I blew my gears apart. If you have a 12 bolt just be aware that the can and will blow your rear if you hook good enough. Your best bet is to get a timing tuner so you can set a delay on your nos .
