nitro daves wet plate kit dyno numbers
150 shot with .38 fuel jett is the first graph. as you can see it went to 10.x's. a little rich so we put in the .35 fuel jet and it ended up at 11.2x's so we felt it was perfect right there. 110 leaded in the dedicated and 93 in the tank.
car made 440 on motor.
ported ls6 heads,england green whiplash cam,lts modded ti's,ported 78mm fast.
If your not worried about it, then who cares.
I picked up 167 RWHP on the 150 pills. Same set-up as you. 110 in a dedicated and 93 in the tank. Thats with a A/F of 11.0 and 22* of timing......
Are you running the same cam, and transmission??? You do not always pick up what the nitrous company states; it's just an estimate of power.
graph looks good
HP doesn't always come out the same, so I would not be concerned
another note is he may have not pulled it to the same RPM as he did on motor just a guess by only seeing 6400 rpm
what was the bottle pressure ? if it was 950 or so i would put the 38 back in and heat it up to 1050-1100. a/f should be somewhere in the mid 11x range and hp will pick up, that is if you are wanting more.i run mine at 24* on spray (dyno only so far) with i think 110 in the stand alone.
anyways your car will be strong on the jug so congrats.
