my hsw nitrous setup
hello
my car is holden commodore ve ss (G8 v8 usa)
trunk 1
trunk 2
inside
inside 2
under the hood
thanks for
dynotune for windows switch and fast shipping and hsw
i have one problem is the hsw gauge is spray all around so i will get another gauge NX this time and purge kit blue led nos
trunk 1
trunk 2
inside
inside 2
under the hood
thanks for
the nitrous run ok and work 100% first switch On secend the green botton to spary
ihave problem with tb so i don't use tps when i know the problem and fix it i connect the tps no problem of i have 4 botton or one same HP
Guest
Posts: n/a
My guess is the Middle east...the steering wheel has the Chevy emblem on it...so it is likely a Chevrolet Caprice ...which is also a rebadged Holden Commodore
Looks like you have a very user friendly install...You have the ability to see what the kit is doing by having the window switch mounted within view.
from kuwait
and its lumina ss a4 with **** torque converter tci breakaway 2400-2600 i must change when i have $$ money lol
windows switch for safety reason
435 before converter and nitrous on dyno jet
after torque converter ,tr6 and 75 nitrous on mustang dyno the car made 412rwhp
and i am happy dyno number only for show
from kuwait
no idon't get the graph
224-230 114 cam
cai
torque converter 2400-2600 tci
3/4 long headers and stock exhaust 2.25 with 2 borla 2.5 mufflers
slp udp 25% + slp 160 deg Thermostats
dyno tune 98 octan fuel afr is about 12.8 timeing 21 (hp tuner)
224-230 114 cam
cai
its vary expensive about 11$ for 1k/g
ican't clean the engine because dust everywhere
winsows swich work great tps and rpm to activation the nitrous
