200 shot w/the parts listed?
Old 11-15-2008, 04:39 PM
dubrado's Avatar
Default 200 shot w/the parts listed?
I am pulling the current motor to rebuid it with these parts, unless you guys say it can't be done.
So far the plan is
-Scat I beams w/ARP rod bolts
-diamond pistons
-nitrous outlet plate (78mm), single stage
-Walboro 255 pump
-making low to mid 400's on motor
Will the motor handle it reliably? Especially since it's single stage?
Also what rings to get?
Will I be fine with ARP bolts instead of studs?
Also, what is the highest compression i should run?
I'm on a budget, that's why I was thinking scat Ibeams.
thanks in advance.
Old 11-16-2008, 04:32 PM
Nitro Dave's Nitrous Outlet's Avatar
You will be fine with a 200. Make sure the fuel system is there. For a 200 ARP bolts will be fine but studs would be better.
Compression wise maybe somewhere around 11.5.1 at most if its a daily driver.
Dave
Old 11-16-2008, 06:19 PM
dubrado's Avatar
Dave
It's not a daily but I drive it on weekends only and track it when I can
