BIG n20 guys inside please
Old 11-16-2008, 05:39 PM
addicted2myWS6's Avatar
Default BIG n20 guys inside please
Ok, here is my situation I have a 408 billet mains, 1/2" head studs, lunati internals w/ diamond pistons. I have two sets of heads siting here, one set will give me 12.5:1 comp and the others will get me right at 14:1. Both heads flow close to each other, so I wouldnt be giving up much flow.
It has a plate and DP kit both stages are pilled for 200 each.
The cam is a high 250's 270's cam on a 113 +2 (hyd)
The car has full suspension and will only be a track car so it will be on race gas at all times.
My question is what compression would you go with and why?
Thanks for any help.
Old 11-16-2008, 06:37 PM
02 BLK WS6's Avatar
14:1 for every last hp, but the only thing that should go in the tank/fuel cell should be c16 or better.
Old 11-16-2008, 06:53 PM
Thats what I was thinking, but I read some where that some of the big boys were backing the compression down a little bit and throwing more nitrous in it.
Also, I have some Q16 going in it, just to try it out.
Old 11-16-2008, 07:23 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Depends on how much you plan on spraying. 14:1 is going to be a massive amount of cylinder pressure with a big shot.
Old 11-16-2008, 07:47 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
I would go with the 12.5 comp heads and hit it harder with more nitrous.Your better off with less compression and more nitrous on the stock blocks.Static compression makes it a bit harder to keep the heads down.
Old 11-16-2008, 07:55 PM
tuff's Avatar
I would also fill the block half way,really locks the bores up from rattling around and keeps them heads down.
Old 11-17-2008, 05:56 PM
Thanks Tuff
That is kinda what I was thinking.
Old 11-18-2008, 11:30 AM
8 second mod
Noyzee's Avatar
i run 14-1 on my car, but i dont hit it hard. 250-300 is about all i do i might bump it up we'll see.
if you plan on hitting it with 400 in 2 stages i would go 14-1 any more then that 12
Old 11-18-2008, 12:48 PM
ShiznityZ28's Avatar
12.5 and hit it harder.
Old 11-18-2008, 01:15 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
yep....
Old 11-18-2008, 03:15 PM
Thanks guys, I think I will go with the lower comp and spray the **** out of it.
Hopefully I will join you all in the 8's, probly not as quik as most of you but I am hoping for at least a 8.99 .lol If not I'll blow the damn thing up trying.
Old 11-18-2008, 03:30 PM
99_pewterZ_A4's Avatar
any news on trmin8r/ sean andersons SS
Old 11-18-2008, 11:18 PM
GueSS Who's Avatar
I had 12.5:1 last year. I know have 14:1 and it made more power N/A. I plan on spraying the same 500 pills on it. I in fact would like to add another 200 on top of that. I have not had one single problem with head lifting. I also have 1/2 head studs with Diamond pistons and Lunati billet internals. Cometic gaskets. I have a big solid roller 279/292 732/732 on a 114, with BIG Dart heads. Made over 600rwhp on the dynojet N/A.
