wet kit speed density iat mod
timing tuner problems
i wanna pull 9 degrees of timing and seems like my timing tuner isnt working...all i got it for was to pull timing...
so ive got a stand alone that power up both of my switches for 1st and second kit...what i wanna do is when my stand alone is on pull 8-10 degrees of timing...how do you go about this? anyone got a decent diagram of what needs to happen so it works fine until i flip the switch then it just pulls timing?
Nick
ya we knew we couldent se timing pulled....yes im pulling timing and not using the window switch....think ray fixed me up...i had the grey wire grounded all the time...and not to the 85 on the relay so im goana fix that up and we should be good...to make sure were goana make a timing mark at tdc on the crank pullie....
I run a timing resistor mod on my SDOL tuned Vette. The timing resistor relay kicks in when I push the switch for the standalone, just like ou had described above. Good luck witht he timing tuner repair/fix
well more testing on the timing tuner ill see if i can get louis to post a pic but my timing tuner was pulling timing until 6k then it jumped back to original timing...mid pull...its hook up to a seperate relay and wired correctly...anyone had similar problems...
we made a motor pull made 420hp pulled 9 with the timing tuner(fakinf the nitrous was on) and it made 35 less hp until 6k then jumped up to 420 again...i cant hand this happening any fix?
