timing tuner
Old 11-24-2008, 06:11 PM
daniel6718's Avatar
Default timing tuner
ok ive got one hooked up through a relay like dave/ray/chris and n20 oulet told me to...
i was dynoing my car at LG motorsports...we made some motor pulls and car did great and smoothe...we FAKED the nitrous was on by giving it 12v, made another pull a few times and it pulled timing(down 30hp, pulling 9 degrees)
then at 6000-6100 its like the timing tuner cut off and it went back to original timing and jumped up 30hp...
anyone have a similar problem? dave can you give me a call???
Old 11-25-2008, 02:27 PM
PAGregSS's Avatar
The timing tuner has a window setting on it. It's likely set at 6100.
Old 11-25-2008, 03:40 PM
daniel6718's Avatar
hmmmm intersting...well i had all the ***** zeroed out...but i can look into that...what should it be set at if you want want the window switch on at all?
Old 11-25-2008, 07:36 PM
Black Sunshine/ 00SS's Avatar
If it did that on even a 75 shot, it could destroy a motor... If indeed it is on a window switch, I'd set that for the max RPM, even if that was 10,000.
The nitrous would be on it's own window switch.
Old 11-25-2008, 09:11 PM
daniel6718's Avatar
yea i know....thats why we didnt spray it...
Old 11-25-2008, 11:37 PM
waterbug1999's Avatar
Was it on some delay? Maybe the dip switched not off? I was reading thru this (I have one as well, but in line with my Nitro daves WS) and I have not used it cause there was no way to tell if it was pulling timing other then the LED...
Its seeing WOT it still should pull timing till let off the gas.
http://www.fullthrottlenetwork.com/a...2&d=1103730053
Old 11-26-2008, 09:51 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Do you have the timing tuner wired exactly like this?
Old 11-27-2008, 09:41 AM
02SOMWS6's Avatar
there is a start and end setting for the nos. You have the end setting at 6000-6100 thats why the timing jumped.
Old 11-27-2008, 08:59 PM
Not for the N20 activation... RTD (whatever its set to) is activated whenever it gets the reference volt.
Old 11-28-2008, 06:45 AM
PAGregSS's Avatar
That's why it's important to know how it's wired in. If the arming switch is wired to the switched ground, the entire system is shutting down, meaning the timing tuner is turning off when he reaches the upper end of the window.
Old 11-28-2008, 09:47 AM
FANCHERFAST's Avatar
when my tuner and i found out that the tuner would not show timing being pulled we actually pulled timing from my tune and then used the timing tuner to add timing when i run N/A. this way we dont have to depend on an electrical defice to hopefully pull timing, we know the timing is being pulled and like i said we manually add timing back when not on the juice. you have to keep adjusting the tuner but its extra insurance.
Old 11-28-2008, 10:44 AM
daniel6718's Avatar
it wired like ray has it...except mine is T'd into the stand along instead of the n20 noid...
Old 11-28-2008, 11:24 AM
I wired mine like ray has it as well... But, i wired the white wire going to the TT to the white wire arming switch. So, I could see that the LED is coming on while at idle.
Old 11-28-2008, 06:08 PM
daniel6718's Avatar
yea my white wire comes from the stand alone which power both of my kits...i can turn on the stand alone and see the red light come on...
dave told me to call somebody who was a timing tuner expert i forgot again...they will be open monday..maybe trick performance?
Old 11-28-2008, 08:28 PM
I would imagine the guy from full throttle. . Maybe Craig if I remember correctly.
we had some issues way back when, they had to re-do a schematic due to my issues that i had that are now fixed. so, above schematic is correct. Thanks again Ray.
Old 11-28-2008, 09:10 PM
daniel6718's Avatar
thats what is was full throttle...i remembered until i read this thread then i went blank....but im goana call monday...if not dave said the leinginfelter box was pretty badass
Old 11-28-2008, 09:19 PM
1BADAIR's Avatar
the max rpm isn't set by the *****. I think the factory setting is like 6100
