11.038 @ 135.13
11.038 @ 135.13
getting better. i tried spraying out of the hole but its not happening on the 18's.
h/c/i/e/175 wet progressive.
stock rear,stock clutch,stock shortblock.
next best of the night was a 11.10 @ 134.59 running my buddy in his whippled/cammed dragged out 03 cobra. im sure there will be vid of me treeing him and taking the win!!
http://files.filefront.com/WizPBwmv/.../fileinfo.html
***edit*** vid added
i ran it on motor before the heads and it went 12's at 118. i havnt run it on motor since the spray tune cause we pulled a bunch of timing and i dont want to know what it does.
the stock clutch is not happy! i tried to come out of the hole tonight aggressive and smoked it. as long as i come out easy and ramp the spray in its holding.
as far as i know the clutch is stock. i bought the car with just under 60k on it and it was bone stock down to the paper filter all ac delco parts. obviously always serviced at the dealership. i cant imagine it has an aftermarket clutch in it.
ported ls6 heads/whiplash cam/78mm fast/1-7/8 ar headers/ti exhaust spray
Great video, that was some funny ****. Awesome Runs, start saving up for a clutch though, i doubt the stock one will hold much longer. Maybe some sticky tires later on with a bigger side wall, rebuild the rear and you just might see a 9.
With that mph and a good 60 ft, 9 should be right there!
Good runs your car has alot more in it with that mph. The one thing i dont understand is that you have all that money in heads cam and what not but couldnt spring for a good clutch and supporting mods? Not bashing just trying to understand.
