timing tuner upgrade?
Old 11-30-2008, 11:35 PM
racerx17x's Avatar
Default timing tuner upgrade?
has anybody seen this? i was looking on there page and found this but no talk of what it "upgrades" . anybody have any ideas as to what it does? maybe it fixes the led problem. here is a link to the page http://http://www.fullthrottlespeed.com/itemdesc.asp?CartId={109FF0C7EVEREST-2684-43EE-A876-3840685CE6B3}&ic=050TIMEUP&eq=&Tp=
Old 12-01-2008, 10:26 AM
Nick@HSW's Avatar
I'm not able to get the link to work. Anyone else get it to work? What are you looking to do with your timing tuner?
Nick
Old 12-01-2008, 10:28 AM
Chris@NitroDaves
Guest
Posts: n/a
Linky no worky
Old 12-01-2008, 11:04 AM
racerx17x's Avatar
i was just looking at there site kinda bored haha. here is the address just copy and paste it. if that link is broken i just did a search for timing tuner and this cam up . http://www.fullthrottlespeed.com/itemdesc.asp?CartId={327BDBF2-7B8A-4A8A-968E-7B05EVERESTB1752765}&ic=050TIMEUP&eq=&Tp=
Old 12-01-2008, 04:27 PM
racerx17x's Avatar
HOME FTSS.Com Items F-Body LT1 / LS1 Performance LS1 Performance LSI TIMING TUNER & N20 CONTROL
LS1 TIMING TUNER UPGRADE
(Click to enlarge) List Price: $29.99 EACH
Qty:
Item Code: 050TIMEUP
Weight: 0.50LB
Categories: LSI TIMING TUNER & N20 CONTROL
Item Description
Upgrade chip for timing tuner to that last latest version
To see a printable version of this Item Click here.
Old 12-03-2008, 07:08 PM
Nick@HSW's Avatar
No its just to update from version 1.0 to version 1.1. The early versions only had two options for top end RPM shut off on the window switch. If you have a selectable dial you already have the update. Thanks.
Nick
