Nitrous heads
Nitrous heads
What heads are the nitrous guys using? Im looking into the Darts they have some serious exhaust flow more than other heads I have reviewed. I want to keep the stock Ls1 style rockers not the Ls7 style. Any suggestions? Im looking to build a motor that will see a 300-400 shot and Yes everything else will be supporting, this is just a question on what heads people are running. Thanks guys.
Race your car!
ET's or Allpro would be your best bet, if you're gonna do the lsx block you want something that can use all 6 studs, and both ET and Allpro can do you a head that will suit your needs, I'd look at them.
If you are set on wanting to use Dart heads, I'd get in touch with one of the good head porters on here, wcch comes to mind. Or, see if you can get in touch with greg good, or someone of that level, head flow for what you want to do is going to be important to say the least.
8 second mod
my tea heads where so nice i hated to put them on my car!!!!! TEA did 100% perfect job on everything. not only was it a good head, but all the machine work and quality that went into them to convert to solid roller etc was just 100% perfect. A++ for TEA, Brian and his crew do great work
Cool, thanks im going to give Brian a shout. I was looking at a set from TEA actually they sell the Darts I was looking at. Good luck with your car Noyzee I hope to be running there with you soon. Can you give me any more specs on your set-up.. more so the head set-up, titanium intakes? What rpm you looking to turn. etc. Price Thanks again!
8 second mod
Brian will probably tell you to go trick flow, but either way he will set you up right.
my heads where tea 245's all done by tea, big springs set up for solid roller the valves where the upgraded stainless, nothing fancy, im on a budget. if i went nuts and had the cash to go nuts im sure i have a good 100 hp in my set up, just dont have the extra 5-7k
new heads i cant talk about just yet, pretty sure tea still hasnt reliesed them
but they will still be pretty basic as like i said, no cash for all the good guy parts and valves etc.
