window switch with nx tps activation
You need both in series.
If you only have TPS then you 'could' spray at 1500-2000 rpm. If you have only the window switch then it 'could' spray without being at WOT. Either of those scenarios could be fatal for your engine.
This obviously is if you are shooting for automatic activation.
