Who is running E85 and Nitrous?
E85 is a very caustic fuel. It eats away at common fuel systems. E85 vehicles require a lot of stainless steel parts to hold the fuel. I dont know if LS1 have those I have not checked but be careful. I think there was a long thread on E85 and what it would take to run it. Try searching. https://ls1tech.com/forums/fueling-i...?highlight=e85 . This should fill in whatever questions you may have.
yes!
yes its possible, http://www.youtube.com/watch?v=lvMzFFxAOuI
the red dart in the end of the video is a street driven small block (carb) on nitrous, works great. Go to www.dynotuneusa.com , i know some people who have had there cars converted and tuned to E85 by them.
Yes it is very possible, my brother ran e85 this summer and I will be this upcoming summer on my ls1. It is not as caustic as you think....
BTW you have to upsize your fuel jets.....
do some reading on E85forum.com
i just did a quick search, there was a guy making over 1200hp on a sbc with e85 and nitrous.
my next motor i would like to setup for e85. 105-107 octane for under $2 a gallon. i dont understand why more people arent switching over. i havnt heard any downsides to it, other than you use 25-30% more fuel. just need to make sure your fuel system is setup for it.
i was going to do the conversion, but ran out of money. e85 is $1.49 a gallon and the station is only 3 blocks from my house. the problem is it requires 30% more fuel. so a car making 550-600hp on motor needs a fuel system that can support 1000hp. and the same goes for the jetting and noids needed. everything needs to be able to handle the additional fuel requirements
Im glad i setup my fuel system way bigger than needed
Yes it is nothing like methanol as far as being harsh on your fuel system. I am running a procharger setup no nitrous but on e85 and I am loving it. Running twin walbro 255 big line and aem fuel rails no problems at all. One of the main reasons I switch was because it burns alot cooler too.
and E85 is a lot easier to come by than race gas at least, cause you can get it at a pump
I ran E85 and nitrous for a year and just switched back to 93. My experience is I made more power N/A and on the jug, but the bullshit of the E85 being really inconsistent, hard to start when its cold out and the gas mileage was horrible. In a nutshell I'll never run that ****.
Here's an example or the gas mileage. I drove to the track on a full tank(12 miles from house) and made 8 passes. 4 on motor and 4 on a 150 shot. Fuel pressure did not change. I used a half a tank and put ~32 miles on it.
Fuel system is a LPA/Nasty stage 3 kit
I've tuned several cars on e85 no problems with any of them. You'll need a fuel system for 23% more fuel thats all thats needed. I've tuned several cars that get within 1-2 mpg's as they did on 92-93 octane
How is that possible with the added demand of Fuel? I find it hard to believe that you have no issues with E85 especially in MN.The summer blend and winter blend of E85 are not the same as more than 15% of gas is added the the E85 during the winter months. When it gets into the low 20's or even colder my car is hard to start. I had to put a few gallons of 93 in the tank to help it start
