FJO writeups?
FJO writeups?
Is there any writeups on installing the FJO.. Im somewhat confused on everything.
Im running a drive by wire c5 vette what color wire will be the TPS for the wot
and whats the RPM input wire..
if someone has a writeup that will help me allot here.
The instructions and diagrams are on the disc that came with the controler they are very easy to understand.
If for any reason you did not get a disc you can download the info direct from FJO's site.
Guest
Posts: n/a
For the Tach you are going to want to look on the passenger side...Where all the coil packs come together into one main plug you are looking for the Male Side ( should be the connector closest too the intake plenum ) there will two rows of wire's. You want the top row ( Closest to you ) and you are looking for the wire second from the left [ reading as left to right ]( it should be either a Dark Green, Green w/ White Tracer, or Aqua colored wire )
