383 lt1 on da bottle for 1st time
Old 12-21-2008, 03:58 PM
th3brandon's Avatar
Default 383 lt1 on da bottle for 1st time
Well guys i got a forged 383 w a set of trickflow gen x heads,847 cam,42lb injectors,and pretty much all the supporting boltons....im still on the stock fuel pump and thinkin of sparying 100shot...my ? is will i be ok to spary this while on the stock fuel pump...i was hopeing to get mid 11s out of her on motor and brake into the 10s on the bottle...can u guys point me in the right way this will be my first time using nitrous.
Old 12-21-2008, 04:15 PM
LS1 SPEED's Avatar
I would suggest against spraying on the stock pump. They are cheap and it's not worth the chance of going lean to see if the stocker might keep up.
Old 12-21-2008, 04:18 PM
DopdBrd's Avatar
What he said. A 255 LPH pump can be had for about 150 dollars or less. Cheap insurance if you ask me.
Old 12-21-2008, 04:23 PM
evilbeef54's Avatar
fuel pressure and/or AFR shut down switch (sofething like on the HSW microedge) would be a good idea, just for some safety
Old 12-21-2008, 04:29 PM
DopdBrd's Avatar
I actually a little suprised you don't already have a 255 LPH pump with that 383 you are running. You are probably pushing that pump on motor alone.
If I were you I wouldn't even think about spraying it until you get a bigger in tank. Just my .02
Old 12-21-2008, 05:27 PM
th3brandon's Avatar
yea the motor should be starting up here in the next couple of weeks...i was thinkin of buying the 255 walbro here shortly
Old 12-21-2008, 05:57 PM
blackls1ta00's Avatar
racetronix!!!
Old 12-22-2008, 09:27 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Will say it one more time...Racetronix.
http://www.nitrousoutlet.com/catalog...product_id=968
Old 12-22-2008, 10:30 AM
Nick@HSW's Avatar
Yup,
I would definitely upgrade the fuel pump and don't forget a hotwire kit.
Nick
