quick NOS Kit question
Hope that somebody can help answer my question here. I have found a really good deal on a universal nitrous kit. only problem is that it is for a v6 import. it is a NOS brand universal wet kit. I have looked on the site and it does not tell me what the difference is between the 4-6 cyl kits and the v8 kit. I would assume that the only difference is the jetting, but if someone knows for sure it would greatly help me out.
Thanx in advance
Thanx in advance
It will work fine as long as the nozzle will work on on your car. If it wont you can pick one up pretty cheap. Just check that the main nitrous line is long enough. You will likely need jets but you probably would on any kit. Not too many differences on universal wet kits overall. If it's a good deal, I would jump on it.
Good luck!!
Good luck!!
