Nitrous Pressure gauge sensor location?
I was wondering what would be optimum? The Pressure gauge sending unit being mounted at the bottle(s) or at the end of the feed line towards the solenoids? If at the end of the feed line before or after the purge solenoid?
Joe
Joe
I have my sensor right before my purge and NOS noid, I also have my old pressure gauge on the bottle still, just never took it off, with my bottle heater on and up to temp, I have only ever seen a 25psi max drop between the bottle and the noid.
Either place is really fine to mount the gauge. I usually mount the electric sending units to the end of the feed line and the small gauges I mount to the bottle itself. On the bigger builds we usually use two gauges to monitor pressure drop across the feedline.
Nick
Nick
Robert
Thanks guys, Im going to go ahead and mount mine right before my purge solenoid as well even though there is not much pressure drop I dont need more wiresw running to the back than I need. Thanks again.
