check my setup ok for a 200shot?
Ms4 cam.
Probe forged pistons 12.8 cr
112 octane fuel
42lbs lucas injectors
255l racetronix fuel pump kit
Carb plate
Dynotune wet kit.
Will I be safe running a 200 shot or can I go higher. Or should I get bigger fuel system? Thanks in advance.
112 octane fuel
Carb plate
Dynotune wet kit.
your def fine, On a dry hit I was spraying around 275 with your exact set-up. So I had to depend on the injectors completely and the duty cycle was still way in the clear. You will def be ok. 200-250 without any problems.
