Feed line and Bracket???
Wanted to know how ya'll route your feed line from the spare tire spot to the engine bay.Pics would be great. Installing my first kit tommorow so any advice would be greatly appreciated!!
Also has anyone used the solenoid bracket provided by HSW. If so what did you mount it to?
i ran mine inside. no pics, but it goes under the plastics along the kick panel on the pass. side through a hole in the firewall. if you remove the computer there is a grommet that has some wires running in it. the main line fits good.
Which bracket do you have?
Thanks
Nick
I also like to route them down the interior passenger side. The only thing I would add to what Nick said is I tape a peice of wireloom on the hose where it goes through the rubber garmet. I do this to keep the hose from ever rubbing against the pcm wires in the future. Just added insurance.
Dave
Dave
Dave
Dave
Nick
What plastic loom do you use. We use a high quality automotive loom that is built to with stand the heat. This keeps it from turning soft and getting distorted like the cheap loom you get from general auto parts stores.
We also only put this loom on the area of the braided hose coming through the fire wall. So no one will ever see it.
Dave
Dave
Thanks guys. I got the feed line routed!!! Now I'm going to mount the Microedge in the center console. The gromet behind the PCM is how I should route the wires? Any tricks to get from there to the console?
Nick
