200 shot + pump gas
Old 01-25-2009, 03:56 PM
dubrado's Avatar
Default 200 shot + pump gas
No standalone fuel system. Assume the motor can handle it.
The fuel pump is upgraded, stock fuel rails.
Can you run 200 wet, tr6's, and pump gas w/o much issue? Just pull timing and good A/F?
Or would you have to run some race gas in the tank?
thanks in advance
Old 01-25-2009, 04:33 PM
BAKED's Avatar
It would be safer to run at least a mix but people do it on pump gas all the time. If the motor has a cam in it or heads/cam then I'd put TR7's in it just to be safe.
Old 01-25-2009, 04:35 PM
jmill96Z's Avatar
Torco with 93 and some TR7's and you might get by.
Old 01-25-2009, 07:51 PM
BAKED's Avatar
With a good tuner it's not that big of a deal. You wouldn't be getting the most power that way but it can be done without issues if done correctly.
Old 01-25-2009, 07:54 PM
jmill96Z's Avatar
That's how I ran most of last year
Old 01-25-2009, 08:05 PM
dubrado's Avatar
How much timing and what plugs were you running?
Old 01-25-2009, 08:06 PM
dubrado's Avatar
Torco? is that an additive? I know they make lots of different fluids, but don't know if they make a gas additive.
Old 01-26-2009, 12:44 PM
jmill96Z's Avatar
Yeah, it's the additive. And, their back in business too.
Old 01-28-2009, 09:41 AM
capt.ld's Avatar
would i be able to run 200 shot on a stock motor with a dirrect port system under the injectors.and i have a stand alone system also.sorry about butting in
Old 01-28-2009, 10:05 AM
jdawg04 4.8's Avatar
ive hit my bolt-on 6.0 with a 200 progressive shot and that with plugs pulled timing and Cali 91 octane pump.
Old 01-28-2009, 10:43 AM
jmill96Z's Avatar
TR7's and I dropped it to 22*
Old 01-28-2009, 11:50 AM
Sprayed 99's Avatar
i ran 200 wet with 20 degrees timing, pump gas and tr6's for a **** load of passes and had zero issues
Old 01-28-2009, 11:25 PM
YoTengoUnPanocha's Avatar
BOOM! jk itll work get a good tune
Old 01-29-2009, 05:22 AM
capt.ld's Avatar
thanks guys i was going to get a real good dyno tune just to be safe.
Old 01-29-2009, 11:28 AM
Nitro Dave's Nitrous Outlet's Avatar
150 is the safety point with a stock bottom end. Anything over 150 you are taking a risk. The lS1 engine has been known to handle a 200 shot when done correctly. Just understand you are taking a risk and the key is in the tune up.
Dave
I would run C-16 in the dedicated since you have one.
Dave
Old 01-30-2009, 03:58 PM
capt.ld's Avatar
what is a c-16?im new to the nos thing.its not going to see the track all the time just if i go im going to hit the bottle.how about can i tune the nos with a diablosport pradator tuner?i just bought one?
Old 01-30-2009, 04:06 PM
jmill96Z's Avatar
C-16 is just race gas. Does the Diablo let you pull about 6 degrees of timing?
Old 01-30-2009, 05:22 PM
5_02ls1's Avatar
Default 100 shot
honestly if i were a n2o newbie id start out with alot smaller shot...
say 100 and work your way up
Old 01-30-2009, 05:31 PM
buzz12586's Avatar
How bad would the TR7s be on motor? Will they foul out quickly?
Quick Reply: 200 shot + pump gas
