Harris Speed Works Stand Alone System
Does anyone have any history with this? It looks like a great piece, but wouldn't mind getting opinions of those who have/had it?
Hmmm... Ok, due to the overwhelming support I believe I will be ordering one! Is it pretty simple to install? I have a line lock system installed right there now, guess I'll have to move it.
I had one and it was descent. My only concern was the supplied brackets to relocate the fuse box's. They didnt fit to well and the fuse box's never stayed put, they were always popping back off.
High or low pressure will depend on what kind of system you are using. Certain plates and other units are designed for high or low pressure. While our plate is designed for high pressure it actually functions very well on low pressure. As for a direct port system you will probably want to go with low pressure. Makes tuning more precise and accurate.
im running a 4 Lightning noid setup(2F 2N) with Parana nozzles in a ported fast. what is the normal starting point to set the fuel pressure at and base the jetting off of? probably going to jet for 175-200hp.
