Huge Moving Sale!! 1 week only!!
Old 02-08-2009, 03:13 PM
LS1TECH Sponsor
Grant@NitroDaves's Avatar
Default Huge Moving Sale!! 1 week only!!
Nitrous Outlet is moving. We do not have an exact day of moving yet but it will be in about a week and a half. We are waiting for the building to have all the data and phone system finished.
To make this move alittle easier on the staff and movers we are holding this one week sale. The goal is to sell alot of the bulk inventory. This lowers our moving cost and puts big savings back into your pocket. We will not have another sale like it! For this week (February 9th - 15th) stay focused on this post. I will be adding items as I get word on what to add.
Do not miss out on these killer deals!
How to Order
Most parts listed will have a link back to our website. You can purchase the item on our website. When you go into the check out page there will be a section for posting notes. In this section it is important for you to type (SELL IT) in order to get the special pricing. If the item listed in this post does not have a link to the website you will have to call in your order at 254-420-3630.
Ok on to the deals!!
1. Brand X Purge kit -This purge kit is a smoking deal. Do not let the low cost fool you. This solenoid is designed to open at pressures as high as 1300psi.
ONLY 55.00
http://www.nitrousoutlet.com/catalog...roduct_id=2890
2. Brand X N20 pressure gauge- This gauge is going to have a black face and liquid filled. Keep in mind the picture on the website shows white face. It is a black face instead.
ONLY 16.00
http://www.nitrousoutlet.com/catalog...roduct_id=3201
3. Nitrous Outlet Glow-N-Dark N2O Pressure gauge- This is the only bottle pressure gauge in the world that will glow in the dark. It has a white face and is liquid filled.
ONLY 24.00
http://www.nitrousoutlet.com/catalog...roduct_id=2546
4. Brand X 10lb Bottle's- Brand X bottle's are black with a high flow valve.
ONLY 120.00
http://www.nitrousoutlet.com/catalog...roduct_id=2958
5. Nitrous Outlet 15lb Bottle's- Nitrous Outlet bottles are black with a high flow valve and dual accessory ports.
ONLY 159.00
http://www.nitrousoutlet.com/catalog...roduct_id=2875
6. Nitrous Outlet Fuel flow tool- This certified gauge is a must to properly dial in your flowing fuel pressure for your nitrous system.
ONLY 179.00
http://www.nitrousoutlet.com/catalog...roduct_id=3531
7. NHRA Blow off Valve- This is a must have to pass tech inspection at the track.
ONLY 16.00
http://www.nitrousoutlet.com/catalog...roduct_id=2550
8. Blow Down Tube- Another must to pass tech inspection. The picture on the site shows a black nut. These are made with a blue nut.
ONLY 10.00
http://www.nitrousoutlet.com/catalog...roduct_id=2516
9. Nitrous Outlet T-shirts- Nitrous Outlet T-shirts are made from 100 percent pure cotton. This sale is only good for in stock shirts. If your color is not instock we will contact you to let you know.
ONLY 10.00
http://www.nitrousoutlet.com/catalog...del=60&dept=11
10. Nitrous Outlet Automatic bottle heater- Nitrous Outlet bottle heaters are designed for the best look, fit, and responce time. The pressure switch is fully adjustable with the closest tolerences on the market.
ONLY 139.00
http://www.nitrousoutlet.com/catalog...roduct_id=2775
11. Nitrous Outlet Dual Stage 78mm plate conversion- Nitrous Outlet is the only company in the world that offers this plate in a dual stage configuration. This will flow 400 hp per stage and offers the best fitment and attomization on the market.
ONLY 265.00
http://www.nitrousoutlet.com/catalog...product_id=997
12. Nitrous Outlet Dual Stage 90mm Plate conversion-Nitrous Outlet is the only company in the world that offers this plate in a dual stage configuration. This will flow 400 hp per stage and offers the best fitment and attomization on the market.
ONLY 265.00
http://www.nitrousoutlet.com/catalog...product_id=994
13. Brand X Nitrous Solenoid- This budget friendly small base solenoid is designed to support up to 200 hp and provide reliable results.
ONLY 50.00
http://www.nitrousoutlet.com/catalog...roduct_id=3503
14. Brand X Fuel Solenoid- This budget friendly small base solenoid is designed to support up to 200 hp and provide reliable results.
ONLY 50.00
http://www.nitrousoutlet.com/catalog...roduct_id=3504
15. 860 HEX to wing adapters- Tired of having to find a wrench to remove your nitrous bottle. We completely understand and that is why we designed the HEX to Wing adapter. Available for both 4 an and 6an main feed lines as well as -8 for the blow down tube.
ONLY 5.00
4an- http://www.nitrousoutlet.com/catalog...product_id=696
6an- http://www.nitrousoutlet.com/catalog...product_id=697
8an- http://www.nitrousoutlet.com/catalog...product_id=698
16. Nitrous Outlet Brand Jets- Nitrous OUtlet has a full line of brass jets. These jets will work in Nitrous Outlet, NX, and Zex systems.
ONLY 3.00 each.
http://www.nitrousoutlet.com/catalog...del=88&dept=11
17. Nitrous Outlet Digital Window Switch- The Nitrous Outlet window switch is the most durable window switch on the market. This unit is designed to take abuse. With its completely sealed and heavy duty construction you can place it in or our of the cabin. This window switch will control 2 stages, has a built in TPS activation option and the gear lock out feature helps aid in traction controll.
ONLY 110.00
http://www.nitrousoutlet.com/catalog...product_id=964
18. Nitrous Outlet Universal Switch panel- This switch panel works on many different applications. I have used it on a C-5 vette, viper and it fits perfectly in the cubby hole in front of the shifter on the F-body.
ONLY 49.99
http://www.nitrousoutlet.com/catalog...roduct_id=2882
19. C5 Bottle Mounts- These mounts epoxies to the floor in the rear of your C5 corvette. It provides a solid mounting surface for bolting your bottle brackets to. Designed for dual bottles
ONLY 99.00
http://www.nitrousoutlet.com/catalog...roduct_id=3460
20. GTO Bottle Mount- This bottle mount bolts to the framing surrounding the fuel tank in the GTO trunk. The bottle will suspend from the air giving you full use of your trunk space.
ONLY 99.00
http://www.nitrousoutlet.com/catalog...roduct_id=2143
I will be adding a great deal of other parts to this post. Pay close attention because the rest of the parts have limited supplies for the special price.
UPDATE:
NOS-14125NOS: 10 and 15lb 7" bottle
http://www.nitrousoutlet.com/catalog...roduct_id=1789
ONLY $41.49 (1 IN STOCK)
NOS-14140NOS: Quick Release Hinged Aluminum for 10 and 15lb Bottle 7" bottle
http://www.nitrousoutlet.com/catalog...roduct_id=1791
ONLY $115.71 (1 IN STOCK)
NOS-15977NOS: Launcher Nitrous Controller 322.58
http://www.nitrousoutlet.com/catalog...roduct_id=2972
ONLY $322.58 (1 IN STOCK)
NOS-15552NOS: -6AN X -6AN, in-line billet aluminum (140 micron)
http://www.nitrousoutlet.com/catalog...roduct_id=1197
ONLY $48.66 (1 IN STOCK)
NOS-13500NOS: NOS Fan Spray Nozzle-Blue
http://www.nitrousoutlet.com/catalog...roduct_id=1227
ONLY $10.70 (2 IN STOCK)
NOS-17255: FLARE JET Y FITTING BLUE
http://www.nitrousoutlet.com/catalog...roduct_id=3261
ONLY $15.73 (1 IN STOCK)
NOS-17256: FLARE JET Y FITTING RED
http://www.nitrousoutlet.com/catalog...roduct_id=3264
NOS-16160NOS: Nitrous Bottle Blow Down Tube
http://www.nitrousoutlet.com/catalog...roduct_id=1667
ONLY $21.70 (1 IN STOCK)
NOS-15907NOS: Fuel Pressure Gauge EFI
http://www.holley.com/15907NOS.asp
ONLY $61.26 (1 IN STOCK)
Let me know if I can answer any questions.
Thanks
Grant
Old 02-08-2009, 03:37 PM
Beer99C5's Avatar
Shoot me a PM with the colors you got for the T-shirts, I need Porno Large (dats XXX...aka XXXL)...
I think Robert is a Large, if you got a large in pink let me know I will buy it and send it to him...
Old 02-08-2009, 04:46 PM
LS1TECH Sponsor
LOL,
We have some a shirt left here that Courtnay had made for there nieces that say My uncle is Nitro Dave. Its already stretched out from Chris putting it on at the LSX shoot out to get a few laughs. Ill send that one if Robert will put it on and post a picture.
Ill get a list on what color shirts we have and post it.
Dave
Old 02-08-2009, 05:17 PM
LS1TECH Sponsor
Ok here is what we have left in T-shirts
White- Med, large, XL, 3X
Black- Medium
Red- Med, XL, 3X
Orange- Med, lg, 2X
TX Orange- Med, Lg, XL, 2X, 3X
Blue- Med, Lg, 3X
Maroon- Med, Lg, XL, 2X, 3X
Grey- XL, 3X
Youth Lime- XS
Youth Lilac- Small
Youth Indigo- XS, M
Youth Pink- XS, S, M
Youth Blue- XS, S, M
Youth White- XS, S, M
Youth Red- XS, S, M,
Youth Black- S, M
Youth Tangerine- XS, S
Old 02-08-2009, 05:33 PM
Beer99C5's Avatar
I'll take one in texas orange and one in grey both XXXL, have Chris hit me with a Paypal invoice when he gets a chance
Old 02-08-2009, 06:16 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Wow, there's a lot of nice deals on there. I wish I had some extra income right now.
Old 02-08-2009, 07:16 PM
porksoda's Avatar
I'm gonna buy some stuff right now! Need a newbie question answered first though.
1.I have a HSW bottle and I need a blow down tube. Do I need both the NHRA fitting and the tube to complete a blow down tube setup?
2.Also what size do I need because I want to buy a wing adapter for the blow down and the main line, are they both 4an?
3.My bottle is mounted in the spare tire compartment with the 860 plate so will the blow down be long enough to reach outside the car? Need a quick answer as I'm ready to buy some hex nuts, shirts, and blow down stuff!
Also when I type in "Sell It" is it supposed to update with the sale price immediately or do you guys just go back and fix it later with the lower prices?
Old 02-08-2009, 08:04 PM
VIPRETR2's Avatar
Will these work with a Nano setup or will I need a different valve?
ONLY 159.00
Old 02-09-2009, 12:05 AM
Badass 2003 Z06's Avatar
The section for posting notes isn't showin up for me...all i see is where u can enter which salesperson helped u?
Old 02-09-2009, 06:48 PM
Truck Sponsor
TrickPerformanceProducts's Avatar
Bump for nice prices. Don't need anything today, but I will be hitting you up for a small noid or two.
Old 02-09-2009, 10:52 PM
zracer323's Avatar
Thats all I'm seeing too
Old 02-10-2009, 08:59 AM
LS1TECH Sponsor
Just put LS1TECH Sale in place of the salesman.
Old 02-10-2009, 02:43 PM
porksoda's Avatar
Any answers for me? I wanna make sure to get this order in early and get everything in one shot.
Old 02-10-2009, 05:47 PM
LS1TECH Sponsor
Yes, the adapter fitting and blow-down tube will be needed.
The blow-down is 8 AN and feed lines for single nozzle/plate kits are usually 4 AN. if you have a direct port it would 6 AN.
It will be long enough to reach through the hump forward of the spare tire but will not reach to the bottom of the spare tire area.
We check the notes/salesman area and will make the necessary adjustments.
Old 02-10-2009, 08:31 PM
Frostbitten09's Avatar
how about a F body Trans tunnel Mount on sale
Old 02-10-2009, 09:30 PM
Ms Eliz's Avatar
How about 20% off all orders over $1000??? I'm ready for a real deal and to help you move less stuff! I've a whole set up to purchse, so let's make it happen!
Ms Eliz
Old 02-10-2009, 09:36 PM
1badA3Z's Avatar
Thats some great deals!
Old 02-10-2009, 10:29 PM
Footlead's Avatar
Default F-body Bottle between the rear seats mount
I will buy one when u put the Tunnel mount tween the rear seats on Sale!!
Old 02-10-2009, 10:37 PM
Nitro Dave's Nitrous Outlet's Avatar
Originally Posted by Ms Eliz
How about 20% off all orders over $1000??? I'm ready for a real deal and to help you move less stuff! I've a whole set up to purchase, so let's make it happen!
Ms Eliz
Actually MS Eliz a Customer appreciation day may be a great idea.
Ill have to put some thought into that. This would be a special day to customers like yourself that have supported us over the years.
Dave
Old 02-10-2009, 11:09 PM
porksoda's Avatar
Thanks again Grant! I actually think it was you also that convinced me to buy the dual channel window switch and explained all it's features to me. LOL And by the way I love it and it functions awesome, I recommend it to anyone and everyone!
I just put my order in now for a few things that I have been wanting. Saved me about $40! Great sale.
