"?" About HSP stand alone system
This may be a stupid question, but on the Harris Speedworks stand alone system, they send you the braided line along with 2 sleeves and 2 other black fittings w/ threads.... Are you suppose to just "thread" the black pieces into the hose and call it a day? The instructions are very detailed in removing the fuse boxes but not so much on the hose... Probably because you're suppose to already know what to do, lol guess I'm dumb. Any help would be awesome! Thanks!
Nick
I've also found that a dremel with a thin cutoff wheel works even better for cutting the hose. It takes a little longer, but makes a smoother, cleaner cut, so the end doesn't try to fray, and is easier to insert into the fitting. Wrap a piece of masking tape around the hose where you want to make your cut. A lot of people cut at the end of the tape, but I have found if you place the tape so you are cutting right in the middle of the tape (cut through the tape and the hose at the same time) it works best. This leaves both ends smooth with a piece of tape still wrapped around them to keep the braid from fraying before you get ready to use it. Just pull the tape off right when you are ready to insert the hose in the fitting.
Nick
