Causes for Nitrous system coming on and going off, then coming on and going off
So I have a wet kit nitrous system on my 99Z28. I am running Compucar solenoids with a FPSS, WOT switch, Zex window switch, and HSW Interface. When I arm the kit and hit it you can feel the nitrous cutting in and out. I have the FPSS set at 45 PSI so if the pressure drops below this it will cut off. Is this too high still do you think? the FPSS is the only thing I can think of that could be causing this. Any thoughts?
I would double check all wiring. A gremlin somewhere, no doubt. It does sound like the somewhat common on/off from a FPSS that isn't set correctly. An easy way totake that out of the picture is to just put both wires on one terminal, and doesn't which one, then you have bypassed it and if the issue goes away, bingo, if not time for more diagnostics.
robert
robert
U gotta set the fpss lower, if u install a pressure gauge u will see that it spikes upon activation and takes a second to recover. Find the point at which it will not "cycle". It will be lower than u feel safe with, just make sure the fuel system is up to the task. Fuel systems w/ the return line/regulator in the back instead of the fuel rails will have the greater temporary pressure drop.
First put a pressure gauge on the car. The Fuel pressure safety switch may be doing its job. Why bypass it? That just defeats the purpose in even having the switch on the car. If you put a pressure gauge on the car and the pressure is droping a few psi when the system hits causing the FPSS to kill the system re adjust it. If the car is having a significant amount of pressure drop you need to work on the fuel system.
If the fpss is not killing the system check the windoswitch connections and settings. Also check the wot switch and make sure the throttle arm is making good contact through the entire rotation.
Dave
Dave
Mine was doing that same thing....drove me cazy lol, I wont go through everything i checked but i had put my hand on the activation switch on the T.B. and moved it ever so slightly and that was 'my' problem. On OFF,On Off lol.
Surprised no one else suggested this yet, but is your bottle installed correctly? If the pickup tube is not at the lowest point in the bottle you'll get surging just like this too. Let's just say I know from experience. :blush:
Thought I'd throw that out there for ya. Otherwise, can you tell if the system is automagically going on/off on its own? If it is then it seems like the fuel system is where you need to look.
-Eagle
-Eagle
If you're having issues with the fuel pressure, address that first by getting a gauge on there. Chances are its the fpss and I see people by-passing them all the time. This is why I'm generally not a big fan of them. For a better way of doing things, take a look at the microEDGE for the a/f shut down capability. If you have an inherent flaw with the cars rear mounted regulator etc and the spike catches up you can program the a/f shut down switch around it with our easy to use menu system. HOWEVER, I am in no way shape or form telling you to ignore the problems you're seeing now. You need to address them first.
Nick
Nick
Once I insatlled a Microedge my FPSS was dumped, not needed.
Robert
