Custum fuel setup experts: I need a little help...
My original plan was to go turbo, but I decided to go N20 instead, I had bought this custom LS1 fuel rail off eBay quite some time ago with turbo in mind. Supposedly it was off the C5R projects. Here is a picture:
It as AN fittings welded to both ends as you can see. I am guessing the firewall side is -6 and the front has -8, but they could be -8 and -10 as I have nothing to really compare it too other then my -6 N20 lines. Also it appears the regulator is sealed off and I seriously doubt it works.
As you can see I have an N20 Outlet plate kit. How do you guys suggest I plumb this system? It is all going into an S10 chassis if that makes a difference. Here are a couple more pictures:
FRONT:
BACK:
Thank you!
FRONT:
BACK:
Thank you!
my .02 is to do a single fuel cell with a single pump my preference is a magna fuel pump inline with 2 filters one before the pump and one after. comming off the second filter with a Y block all the same size ends. one of the points on the Y can go to a magnafuel regulator and than into your fuel solenoid. the other part of that why can continue on into another Y that will go into one side of your rails, come off the other side of the rails into another regulator with one return back to the fuel cell. if you would be interested in more details on this type of setup such as reccomend part numbers for all of this stuff. pm me and i would be more than happy to help you.
