ZEX kit. Do I need a tune?
I have a 02t/a, Full bolt ons,built trans,3600 stall, and I want to get the ZEX wet kit for it. And I already have a dyno tune. I dont think I need a other one do I ? The kit says it adds and adjust fuel accordingly so it wont let you go to rich or too lean.. And I want to spray a 125 shot. Will I be ok? Any tips/advice is appreciated.
pulling timing is recommended, i'd say definatly since you already have a dyno tune chances are that they added a bit of timing already so you will definatly want to pull some timing. Also make sure you check plugs or do some datalogging to make sure that everything is running correctly, start with pulling 5* and work from there, if you want to keep your current tune for NA driving and have the timing pulled only when the n2o comes on you could look into the HSW interface
Nick
The Zex system is a great beginner system. You are limited in future grwoth but if you do not plan to go over 150 HP it will work. make sure you get a ZEX windowswitch as well. This is the only windowswitch that workes well with there system.
The Active fuel management marketing can be very misleading. Even with the Zex system you need to varify the cars airfuel. The Zex system is using the fact that the nitrous discharge at the bathtub of the nozzle is oulling vacumme on the fuel tube. They are using the fact that the amount of nitrous flowed will aid different amounts of vacumme. This works to a certain extent but can cost you a motor if relying on it to make sure the tune is right.
As for timing controll. The most reliable and safe way is to either do it through PCM tuning or a device that will remove timming. There are only three reliable devices that I would use.
The lingerfelter, MSD timing twister, or timming tunner.
We carry the largest selection in systems and accessories including ZEX. If I can help in any way please let me know.
Dave
Dave
