Moving Sale Has Been EXTENDED!!
LS1TECH Sponsor
Nitrous Outlet is still moving but we have extended the sale up until the last few seconds before the move. The sale in good through Wednesday February 18. Hurry up and take advantage of the savings while they last.
Do not miss out on these killer deals!
How to Order
Most parts listed will have a link back to our website. You can purchase the item on our website. When you go into the check out page there will be a section for posting notes. In this section it is important for you to type (SELL IT) in order to get the special pricing. If the item listed in this post does not have a link to the website you will have to call in your order at 254-420-3630.
Ok on to the deals!!
1. Brand X Purge kit -This purge kit is a smoking deal. Do not let the low cost fool you. This solenoid is designed to open at pressures as high as 1300psi.
ONLY 55.00
http://www.nitrousoutlet.com/catalog...roduct_id=2890
2. Brand X N20 pressure gauge- This gauge is going to have a black face and liquid filled. Keep in mind the picture on the website shows white face. It is a black face instead.
ONLY 16.00
http://www.nitrousoutlet.com/catalog...roduct_id=3201
3. Nitrous Outlet Glow-N-Dark N2O Pressure gauge- This is the only bottle pressure gauge in the world that will glow in the dark. It has a white face and is liquid filled.
ONLY 24.00
http://www.nitrousoutlet.com/catalog...roduct_id=2546
4. Brand X 10lb Bottle's- Brand X bottle's are black with a high flow valve.
ONLY 120.00
http://www.nitrousoutlet.com/catalog...roduct_id=2958
5. Nitrous Outlet 15lb Bottle's- Nitrous Outlet bottles are black with a high flow valve and dual accessory ports.
ONLY 159.00
http://www.nitrousoutlet.com/catalog...roduct_id=2875
6. Nitrous Outlet Fuel flow tool- This certified gauge is a must to properly dial in your flowing fuel pressure for your nitrous system.
ONLY 179.00
http://www.nitrousoutlet.com/catalog...roduct_id=3531
7. NHRA Blow off Valve- This is a must have to pass tech inspection at the track.
ONLY 16.00
http://www.nitrousoutlet.com/catalog...roduct_id=2550
8. Blow Down Tube- Another must to pass tech inspection. The picture on the site shows a black nut. These are made with a blue nut.
ONLY 10.00
http://www.nitrousoutlet.com/catalog...roduct_id=2516
9. Nitrous Outlet T-shirts- Nitrous Outlet T-shirts are made from 100 percent pure cotton. This sale is only good for in stock shirts. If your color is not instock we will contact you to let you know.
ONLY 10.00
http://www.nitrousoutlet.com/catalog...del=60&dept=11
10. Nitrous Outlet Automatic bottle heater- Nitrous Outlet bottle heaters are designed for the best look, fit, and responce time. The pressure switch is fully adjustable with the closest tolerences on the market.
ONLY 139.00
http://www.nitrousoutlet.com/catalog...roduct_id=2775
11. Nitrous Outlet Dual Stage 78mm plate conversion- Nitrous Outlet is the only company in the world that offers this plate in a dual stage configuration. This will flow 400 hp per stage and offers the best fitment and attomization on the market.
ONLY 265.00
http://www.nitrousoutlet.com/catalog...product_id=997
12. Nitrous Outlet Dual Stage 90mm Plate conversion-Nitrous Outlet is the only company in the world that offers this plate in a dual stage configuration. This will flow 400 hp per stage and offers the best fitment and attomization on the market.
ONLY 265.00
http://www.nitrousoutlet.com/catalog...product_id=994
13. Brand X Nitrous Solenoid- This budget friendly small base solenoid is designed to support up to 200 hp and provide reliable results.
ONLY 50.00
http://www.nitrousoutlet.com/catalog...roduct_id=3503
14. Brand X Fuel Solenoid- This budget friendly small base solenoid is designed to support up to 200 hp and provide reliable results.
ONLY 50.00
http://www.nitrousoutlet.com/catalog...roduct_id=3504
15. 860 HEX to wing adapters- Tired of having to find a wrench to remove your nitrous bottle. We completely understand and that is why we designed the HEX to Wing adapter. Available for both 4 an and 6an main feed lines as well as -8 for the blow down tube.
ONLY 5.00
4an- http://www.nitrousoutlet.com/catalog...product_id=696
6an- http://www.nitrousoutlet.com/catalog...product_id=697
8an- http://www.nitrousoutlet.com/catalog...product_id=698
16. Nitrous Outlet Brand Jets- Nitrous OUtlet has a full line of brass jets. These jets will work in Nitrous Outlet, NX, and Zex systems.
ONLY 3.00 each.
http://www.nitrousoutlet.com/catalog...del=88&dept=11
17. Nitrous Outlet Digital Window Switch- The Nitrous Outlet window switch is the most durable window switch on the market. This unit is designed to take abuse. With its completely sealed and heavy duty construction you can place it in or our of the cabin. This window switch will control 2 stages, has a built in TPS activation option and the gear lock out feature helps aid in traction controll.
ONLY 110.00
http://www.nitrousoutlet.com/catalog...product_id=964
18. Nitrous Outlet Universal Switch panel- This switch panel works on many different applications. I have used it on a C-5 vette, viper and it fits perfectly in the cubby hole in front of the shifter on the F-body.
ONLY 49.99
http://www.nitrousoutlet.com/catalog...roduct_id=2882
19. C5 Bottle Mounts- These mounts epoxies to the floor in the rear of your C5 corvette. It provides a solid mounting surface for bolting your bottle brackets to. Designed for dual bottles
ONLY 99.00
http://www.nitrousoutlet.com/catalog...roduct_id=3460
20. GTO Bottle Mount- This bottle mount bolts to the framing surrounding the fuel tank in the GTO trunk. The bottle will suspend from the air giving you full use of your trunk space.
ONLY 99.00
http://www.nitrousoutlet.com/catalog...roduct_id=2143
I will be adding a great deal of other parts to this post. Pay close attention because the rest of the parts have limited supplies for the special price.
UPDATE:
NOS-14125NOS: 10 and 15lb 7" bottle
http://www.nitrousoutlet.com/catalog...roduct_id=1789
ONLY $41.49 (1 IN STOCK)
NOS-14140NOS: Quick Release Hinged Aluminum for 10 and 15lb Bottle 7" bottle
http://www.nitrousoutlet.com/catalog...roduct_id=1791
ONLY $115.71 (1 IN STOCK)
NOS-15977NOS: Launcher Nitrous Controller 322.58
http://www.nitrousoutlet.com/catalog...roduct_id=2972
ONLY $322.58 (1 IN STOCK)
NOS-15552NOS: -6AN X -6AN, in-line billet aluminum (140 micron)
http://www.nitrousoutlet.com/catalog...roduct_id=1197
ONLY $48.66 (1 IN STOCK)
NOS-13500NOS: NOS Fan Spray Nozzle-Blue
http://www.nitrousoutlet.com/catalog...roduct_id=1227
ONLY $10.70 (2 IN STOCK)
NOS-17255: FLARE JET Y FITTING BLUE
http://www.nitrousoutlet.com/catalog...roduct_id=3261
ONLY $15.73 (1 IN STOCK)
NOS-17256: FLARE JET Y FITTING RED
http://www.nitrousoutlet.com/catalog...roduct_id=3264
NOS-16160NOS: Nitrous Bottle Blow Down Tube
http://www.nitrousoutlet.com/catalog...roduct_id=1667
ONLY $21.70 (1 IN STOCK)
NOS-15907NOS: Fuel Pressure Gauge EFI
http://www.holley.com/15907NOS.asp
ONLY $61.26 (1 IN STOCK)
Let me know if I can answer any questions.
Thanks
Grant
How to Order
ONLY 55.00
ONLY 16.00
ONLY 24.00
ONLY 120.00
ONLY 159.00
ONLY 179.00
ONLY 16.00
ONLY 10.00
ONLY 10.00
ONLY 139.00
ONLY 265.00
ONLY 265.00
ONLY 50.00
ONLY 50.00
ONLY 5.00
ONLY 3.00 each.
ONLY 110.00
ONLY 49.99
ONLY 99.00
ONLY 99.00
UPDATE:
Thanks
Grant
Great sale! Everybody needs to get in on this while they can, saved myself about $40-$50! I put in my order last week, Grant called the next day to make sure I ordered the correct stuff, everything got sent out Thursday nite and I received it all today. Great service! I will wear these Nitrous Outlet shirts proudly!
Dave
