Can I run 100 dry shot on my 2004 Z06?
I am now thinking of goin with the 100 shot, but wanted to know if I could even run it with my stock set up? I have 28.8 LB injectors with about 60psi fuel pressure. I also have stock fuel pump in the car. I am preparing to order the HSW interface to add fuel, and pull timing.
Opinions please or anyone running this set up would be appreciated
I've been using a 100 dry shot AFTER the MAF with the Interface and everything has been working perfect. No timing pulled on the 100 shot, but you should still check to see if your car can do that.
I just got bigger injectors and will be stepping up to a 150 shot.
