Help with leaking fittings
Old 02-20-2009, 04:41 PM
brickonwheels's Avatar
Default Help with leaking fittings
HSW has supplied me with a fitting to plumb up my purge to the nitrous solenoid, but the darn thing wants to leak no matter how much I tighten it. I know not to use teflon tape, so what should I use to seal this up?
Old 02-20-2009, 04:44 PM
Nick@HSW's Avatar
You need to get some sealant on the NPT ends. Teflon paste or red loctite will do the trick. If you have a fastenal around they carry loctite thread sealant as well. Any auto parts store should have the other two.
Nick
Old 02-20-2009, 04:47 PM
Saweet. I can finally get it all working propery. All that is needed how is to find a replacement for my fouled heater and I will be spraying away!
