Some excellent tech info about nitrous oxide
Many folks don't understand how nitrous oxide works, and thus struggle to increase power when increasing the jetting. Remember that the "LS1 kits" you buy for these cars are designed using a more or less stock LS1. With that in mind, when you change the basic configuration of your engine (basically an air pump), you change the requirements of the engine to make power using N2O as a catalyst.
There is some "must read" information on Holley's web site that every nitrous user should understand:
http://www.holley.com/HiOctn/TechSer.../NOSTech3.html
