have turbo want to add nitrous
Old 05-18-2009, 08:32 AM
mike13's Avatar
Default have turbo want to add nitrous
I have a single turbo 8lbs boost would like to add 75-150 shot of nitrous what do I need besides the basic nitrous kit? All the information you can give would be great, I have very little knowledge of nitrous looking forward to the help. Thanks in advance.
Old 05-18-2009, 08:36 AM
ATVracr's Avatar
150 shot on top of 8lbs of boost would be fun.
Why not just crank up the boost?
Old 05-18-2009, 08:52 AM
Mike@HSW's Avatar
What size turbo do you have? what motor is this on? whats the reason you want to add nitrous?
Old 05-18-2009, 09:30 AM
mike13's Avatar
T67 turbo, stock displacement. Yes turning up the boost would be very easy but I love the feel and drivablity of the car now, I'm wanting to add power only when wanted and only on the top. Here's a scenerio my car pulls hard from bottom to top end. 3200 stall, 3.73's so if the car is hooked and pulling hard at the 1/8th I would like to be able to add a small shot of nitrous. I know I can set up a progressive boost control, etc. But when the tracks good, weathers good it would just be nice to add some extra power without messing with my base combination.
Old 05-18-2009, 09:42 AM
mike13's Avatar
I just want to be clear, It's not some fast and the furious ego thing, my base combination makes good power works well, I just don't want to be messing with it and making changes. If I can add a extra 100 at times that would be great. So those days when my limited driving talent isn't at it's limit and the track makes amatuers like me look good I would like to have a extra 100hp on the top end of the track.
Old 05-18-2009, 11:38 AM
ATVracr's Avatar
You want to add 100hp or 100 shot?
With 8lbs of boost you probably need a 50 shot to make 100 more hp.
Old 05-18-2009, 11:44 AM
Nitro Dave's Nitrous Outlet's Avatar
Not a problem at all. Adding Nitrous is a great way of maintaining the drivability and adding power with out having to boost the hell out of your set up.
Like ATV stated you will see a bigger gain using the same jetting with your set up VS a boosted set up.
Something Like a simple single nozzle kit will work fine. Although the plate system would look alittle cleaner.lol
Here is a list of Accessories and what there purpose is. Let me know if I can answer any questions.
http://www.nitroustech.com/forums/showthread.php?t=2
Old 06-29-2009, 03:20 PM
mike13's Avatar
Can someone explain that to me? I'm looking for a 100-125hp increase.
Old 06-29-2009, 04:00 PM
ATVracr's Avatar
The boost loves nitrous, start with a 50 shot and work your way up to the power level you want. 50 shot may be all you need to make 100 more hp.
It does 2 things ... forces the nitrous into the motor and cools the charge way down, thats why it will make alot more than a normal nitrous set up.
