Timing and Spraying?
Old 11-04-2003, 10:31 AM
1sweet00SS's Avatar
Default Timing and Spraying?
My timing is currently at 20*. I was told I should not spray with 20* of timing. I was told 26* of timing is ideal. I'm currently going through withdrawals of my NO2 (I feel like a crackhead hahahha!).
My question is: Can I spray with 20* of timing on my H/C car, or should I get it re-tuned and have the timing set at 26*? I currently have a NX Wet set-up, and was planning on spraying anywhere from 50 - 100 shot. I already have TR6 plugs, and usually run 100 octane mixed 50/50 with 91 when I spray.
Thanks
Old 11-04-2003, 02:13 PM
6 Second Club Moderator
LASTLS1's Avatar
20* is VERY safe. It wouldn't hurt anything. With the fuel you use and the amout of spray, you could easily run 28*. Who ever told you not to srpay with 20* to add more for safty.... Well don't ask them anymore nitrous questions!
Old 11-04-2003, 03:04 PM
beardWS6's Avatar
Jayson at MTI tuned and built my car. He set the timing at 26* and alittle rich for the spray. I lost maybe 10-15rwhp N/A like this but I got 135rwhp with 100 wet shot. I love it and I`m safely tuned. Check sig for my numbers. I have A4,12-bolt and all! Bottle psi was 900 at the time. Good Luck!
Old 11-04-2003, 03:10 PM
7 Second Club
NicD's Avatar
For a 100 shot I would pull 2 degrees out from stock (28) if you are running good gas.
Old 11-04-2003, 11:32 PM
Restricted User
CAT3's Avatar
I thought it was supposed to be 2* per 50hp shot size...anyway, my stock timing was at 33*, checked it with 3 different methods, Predator, A-tap, EFILive..Now its at 28*, but going to be about 23* for the 180hp NXL shot. Good luck and have fun..
Old 11-05-2003, 11:59 AM
7 Second Club
NicD's Avatar
That 2 per 50 is a general guideline. Different combinations, different gas, etc will change things. All 2000 f-bodies that I have seen have 28 degrees at WOT stock verified with LS1edit. If you are seeing 33, something is up.
Old 11-05-2003, 04:44 PM
Restricted User
CAT3's Avatar
Yep, found out the Predator performance tune (Generic one I got at first) bumped my timing!
Old 11-05-2003, 05:02 PM
SSU Moderator
RyanJ's Avatar
i always thought it was 3* per 100hp shot? oh well. I'd bump the timing top 25-26 degree's if you are staying with 150hp or less.
Old 11-05-2003, 07:41 PM
4thGENRETARD's Avatar
Yeap, 26* is good with the fuel mix you having. But depending on your AFR also. Do trial and run with ATAP till you reach max, then down tune 1* for safety.
Old 11-06-2003, 07:50 PM
1sweet00SS's Avatar
Thanks everyone for your replies. I'm gonna spray it and see how she likes it.
Thanks again!
