Nitrous Pros. input needed!!!!! .........
Old 05-19-2009, 06:00 AM
1stIDFO's Avatar
Post Nitrous Pros. input needed!!!!! .........
I have a stock bottom end H/C/I 02 SS M6 with around 55k im currently pushing 438rwhp to a 10-bolt(the new rear is being built)When will I start running into Probs. as far as my bottom end holding up? How much can I spray safely,how should I (wet,dry,direct port?)Thanks for the help................
Old 05-19-2009, 06:38 AM
jeepers_88's Avatar
there is an exact sticky in this forum thats titled "how much can my bottom end hold". Maybe that will help answer your question.
Old 05-19-2009, 09:30 PM
WE TODD DID's Avatar
It all depends on how good your tune-up is. I've run 350 through a customer's cam only long block, and is has hundreds of passes on it. Not to mention, the car is his only form of transportation.
Old 05-20-2009, 03:54 AM
1stIDFO's Avatar
OK thanks,,,,,would there be any real advantage going direct port over a regular wet system?
Old 05-20-2009, 06:14 AM
ATVracr's Avatar
Tunability.
Old 05-20-2009, 09:59 AM
8 second mod
Noyzee's Avatar
8 second mod
Noyzee's Avatar
Old 05-20-2009, 06:24 PM
The sticky is full of mis-leading information.
Old 05-20-2009, 06:29 PM
w&a racing's Avatar
we had a heads cam car with 400 on it......never hurt a thing....if u can read plugs and keep ur bottel pressure right u should have no trouble
