Finally got tuned
Old 05-20-2009, 10:47 AM
miller456's Avatar
Default Finally got tuned
Well I finally got my car tuned on a mustang dyno, so remember that is going to be much lower than dynojet numbers and im really happy with the results. This was with the mods in my sig plus a 150 shot . First one is my n/a run second is the n2o run.
Vid:
http://1320video.com/vids/5.25.09RyanDyno.wmv
Old 05-21-2009, 10:51 PM
PONTIAC SLP's Avatar
that system gave u 125rwhp , what sstem is that ? wet or dry ? and what nitrous pressure u r running with ? badass #'s , how u love your pro 5.0 shifter ?
Old 05-22-2009, 09:49 AM
miller456's Avatar
its a harris speedworks wet kit and the pressure was just at or a tad above 1000psi. So far I love the pro 5.0, i have a rip shifter with a ws6store short stick. The only problem with the short stick is its not angled so it will hit the console in reverse but no big deal for me. I couldve gained more actually but my tune was somewhat conservative cuz i dont really want to blow it up anytime soon and its set pretty safe where its at.
Old 05-22-2009, 10:46 AM
Chris@NitroDaves
Guest
Posts: n/a
Nice #'s
-Chris
Old 05-24-2009, 12:40 AM
i ordered that shifter for my cousin with the short stick package i hope he will love it , i have the ms4 also and planning now to adjusting and spray from 125 to 200HP but i have diamond pistons and forged rods installed that will able to spray +200 , by the way good luck
Old 05-24-2009, 12:46 AM
ToBiN!'s Avatar
Nice numbers. Seems I will be installing a similar setup here soon. I hope to at least hit those numbers if not better. Right now I am on 100Hp shot, LTs, 80mm, stock LS1. going to add CNC'd 241 heads, PRC Dual springs, Weiand LS6 Intake, 85mm plate, 85mm Professional Products Throttle body, 42# injectors and a torquerV2. May jump my N2o Up to 150 shot to break 600 if possible. I will let you all know.
Old 05-24-2009, 08:14 AM
WE TODD DID's Avatar
Was the nitrous breaking up on that pull? That dyno graph doesn't look right.
Old 05-24-2009, 02:48 PM
miller456's Avatar
No the nitrous never once broke up thats the car pulling from 44mph n/a then hitting spray, spinning a little, then catching and staying in the spray.
I could have gained a little more out of it if i wanted to do max effort, but i wanted to be a little conservative and safe. I'll go test the car on a dynojet just for bragging right number's but this was a mustang dyno so the numbers will always be lower. I'm very happy with what it put down.
Old 05-24-2009, 10:28 PM
miller456's Avatar
I got the vid up in the OP for you guys if you want to check it out.
