11.5:1 + 200hp, Gas & Plugs?
Old 05-26-2009, 02:48 PM
hashtagBMW
Speed Density's Avatar
Default 11.5:1 + 200hp, Gas & Plugs?
Motor is 11.5:1 398ci LT1.
I've been researching the past few days on this topic, I feel like if got it sorted out but Ill ask ya'll.
AR3933 with a mix of C10/93 in the main tank? Plug is #9, maybe step it back to a 3924 which is an #8. Fuel is fed with a magnafuel 4302 pump.
Id like a tuneup that I can run pump gas only but I would like to be safe on the dyno hence the gas mix.
Ideas? Opinions?
Old 05-26-2009, 03:18 PM
Nick@HSW's Avatar
Ideas? Opinions?
Where did you get that plug number from? I wouldn't use a projected tip plug with that set up at all. A NGK heat range 8 in an autolite non-projected is a AR3934.
Have you sprayed the car yet to know if you can step down a full heat range or is this your base set up? I would much rather tell people to start out cold and work your way down. What are you looking to run for timing?
Keep the AR3933 in there for a few pulls/runs. See what they look like. If you want to bump it back a heat range use a AR3934, just make sure she'll be happy with a hotter plug.
Nick
EDIT**Before I get 10 million PM's about these plugs, they are all gasket'd plugs and shouldn't be used for a taper seat**
Old 05-26-2009, 03:32 PM
hashtagBMW
Nick,
I typo'd the 3924, it was supposed to be 3934 whichi is a non-projected #8, sorry!
This is my base setup, I have never used nitrous. Never run this car on motor or anything. I have 3924s in it now for warm up etc.. but no way on the hose would I run projected. As many have said, start cold and work up thus the #9 to begin with.
As far as the octane, 93 w/ 10% ethanol enought to keep the car alive or is race gas of some sort needed?
Old 05-26-2009, 04:05 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
I run
3935 NA
3934 for up to 200
3933 for 200+
Old 05-26-2009, 04:10 PM
hashtagBMW
Ray,
You have C16 in your dedicated on a low pressure system right?
Old 05-26-2009, 04:35 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
yes...
Old 05-27-2009, 04:39 PM
hashtagBMW
Still need some help on this! LT/LS shouldnt matter, cold plugs and race gas is the discussion!
Old 05-27-2009, 04:57 PM
bjamick's Avatar
You want to be safe on the dyno? Then go with the #9 plug and put her on the dyno and make a pull and pull a plug. If its to cold then put the 8s in. Bad thing about it is that your tuning it with race fuel so you may not get any detonation on the dyno but on 93 only you may. Set your timing at a safe mark also and work your way from there on the dyno.
Old 05-28-2009, 05:17 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
answer your phone....
I am not online much.
