NX direct port jetting HELP
Old 05-28-2009, 09:38 AM
4U2NV-SS's Avatar
Default NX direct port jetting HELP
Hey I purchased a NX direct port pihrana nozzle kit for my Fast 90 and it came with some Speed inc high flow rails. I am connecting it to my stock fuel line with a Walbro 255 intank and hot wire. Good price from a member i could not pass up for my future build!
I do not have a fuel pressure gauge currently on the car, I have gauge but no pillar pod yet. PSI should be like 58 PSI right?
I need to buy jets for the direct port kit, I am dyno tuning on Saturday, I want to start small at like a 150 and move up to a 200 just for tuning, 300 for the future. What jets should I run on the nitrous and fuel side. I call NX 3 times and got 3 different answers.
I looked at there site and and only one tech had the same answer for 200 N-26 F-14 jets nothing for 150 hp!
another told me 200hp N-26 F-16 and 150hp N-24 F-12
3rd said 200hp N-26 F-16 and 150hp N-24 F-16
What jet are you guys running and what should I start at to be safe. I know it is over kill system for a 150 and 200, but it is new to me and I want to start small and work up.
Thanks for you help!!! Art
Old 05-28-2009, 09:49 AM
Nitro Dave's Nitrous Outlet's Avatar
On the 150 use a 14 jet for the fuel.
Keep in mind these are starting points for your tune up. The reason why you got two different answers were breaking the jetting on a directport into 50hp increments gets tricky. They have changed there flow jetting several times so technically either would probably work. I would start with a 14 jet though.
Looking at your mod list I can tell you you the odds are very high you are going to see a drop in fuel pressure causing a lean spike even with the fuel pump and hotwire kit.
When the solenoids open it will require a sudden burst in pressure to fill the distribution blocks and lines. What you have fuel system wise will be taxed very hard and struggle to recover. If I were you I would look into our dedicated fuel system or a dual intank set up relocating the regulater to the fuel rail. Our dedicated is much cheaper...
Dave
Old 05-28-2009, 09:58 AM
4U2NV-SS's Avatar
Thanks Dave,
So N20 - 24 and Fuel -14 for starters
Should I tap into the fuel line right at the connection from stock line to the -8AN line or at the cross over tube point. I do have the farthest point of the rail blocked off, or should I tap into that for the fuel solenoid?
Yeah your dedicated system will be my next purchase, if I get my bonus
And you probably think 200hp it to much for the fuel system?
Old 05-28-2009, 10:04 AM
No problem. I would come out of the caped off end of the fuel rail. Yes I really belive 200 will be a bit much. The 150 may give you trouble. But then again every car is different. Just put a fuel pressure gauge on the car and watch it.
Let me know if you need any advice. I am only a phone call away.
Dave
Old 05-28-2009, 10:15 AM
4U2NV-SS's Avatar
Calling you now!!!
Old 05-28-2009, 10:35 AM
Good talking to you..
Old 05-28-2009, 11:59 AM
NXZ28's Avatar
Dave is who my NX direct port came from. I am using a Granatelli 250lph in-tank pump and an accumulator on the fuel side. I have run a 250rwhp shot on my car many times with no issues at all except it broke my 12 bolt once and my tranny. Here is the jet sizes I use.
20N 12F = 125rwhp
24N 14F = 175rwhp
26N 14F = 200rwhp
28N 16F = 240rwhp
29N 16F = 258rwhp
30N 16F = 275rwhp
31N 17F = 300rwhp
Just like Dave said, every car is different. I never took mine above the 258rwhp shot. I wasn't too worried about hurting the motor because I have a new engine that is waiting to go in. Good luck with it.
Old 05-28-2009, 03:05 PM
Truck Sponsor
TrickPerformanceProducts's Avatar
26 14 is too lean for a 200shot on a V8 @55-58psi.
Old 05-28-2009, 04:51 PM
4U2NV-SS's Avatar
20N 12F = 125rwhp
24N 14F = 175rwhp
26N 14F = 200rwhp
28N 16F = 240rwhp
29N 16F = 258rwhp
30N 16F = 275rwhp
31N 17F = 300rwhp
Thanks!
Old 05-28-2009, 04:57 PM
4U2NV-SS's Avatar
GREAT talking to and THANKS for the info. A+++++++ service
Old 05-28-2009, 04:58 PM
4U2NV-SS's Avatar
What's your suggestions then????
Old 05-28-2009, 06:42 PM
NXZ28's Avatar
I have about 90 passes on mine with this jet setup without ever hurting anything. It could be in the tune also though. To be safe you could put a 15 Fuel jet in it.
Old 05-29-2009, 12:49 PM
4U2NV-SS's Avatar
Is that on your forged bottom end?
Old 05-29-2009, 03:17 PM
NXZ28's Avatar
Yes. Just make sure you have a good nitrous tune and use the NGK BR7E plugs for the 200hp shot.
Old 05-30-2009, 10:35 AM
N20SS's Avatar
I'm sure you are already aware of this, but make absolutely sure you have good filters on the fuel side. The orifice in the jet for a high pressure fuel system on a 150 shot directport is tiny. One tiny piece of trash in the fuel jet and you have problems. Just something to think about. If you go with a standalone later you can switch to a low pressure fuel system, and use bigger fuel jets. You are doing right talking to Dave. He knows his stuff, and will lead you the right direction. I bought all the stuff to build my custom directport from Dave.
Old 05-31-2009, 11:50 PM
4U2NV-SS's Avatar
N20SS PM'd you
Quick Reply: NX direct port jetting HELP
