Those who use AEM widebands
Old 06-04-2009, 08:55 AM
BigDB's Avatar
Default Those who use AEM widebands
How long is the lead from the sensor to the gauge? I want to put it on my A-pillar but the bung will be at the Y in the exhaust. Also the output for a reference signal either datalog or signal to a contoller, how long is that cable? I need to run it to a nitrous contoller to reference the AFR and if it goes Lean/Rich it'll cut the kit off.
Old 06-04-2009, 08:59 AM
Grifter's Avatar
I run an Innovate LC-1 with XD-16 gauge but a lot of my friends use the AEM unit. I'm pretty sure there's enough wire to run from the y-pipe to the a-pillar. I know my Innovate has plenty of wire. You can save some wire but routing it up through the shifter boot(the rubber one that's screwed to the body, under the column panel and up to the a-pillar.
Old 06-04-2009, 09:40 AM
Mean Green z28's Avatar
there's plenty, you'll be fine. Also, I'd get the LC-1 if you can over the AEM
Old 06-04-2009, 11:02 AM
BigDB's Avatar
and y do u say that? Alot of people have said get a LC1 but have no info to justify the extra price
Old 06-04-2009, 01:17 PM
robsquikz28's Avatar
the AEM will be perfect and can easily reach the y pipe routing it the way you say you want to.
Old 06-05-2009, 10:47 AM
mattl31's Avatar
im running the AEM. pleeeeeeenty of cable from the y to the pillar. your analog outputs for data logging will have to be soldered to the harness that comes with the AEM wideband though. its i believe 3 wires with a plug on the end. they are only about 6 inches long, so you'll just splice in some wire cut to whatever length you like.
Old 06-05-2009, 02:12 PM
BigDB's Avatar
Thanks for the info man, thats perfect
