Spray and an MS3
Old 06-06-2009, 10:38 AM
Italiankid77's Avatar
Default Spray and an MS3
How many of you guys have done,and do you like it??What are some #'s you put down with it.
Old 06-06-2009, 08:33 PM
camscam02's Avatar
Old 06-06-2009, 08:52 PM
pozesd99''s Avatar
whats size shot and what suspension
Old 06-06-2009, 09:51 PM
camscam02's Avatar
150. qa1's torque arm regular stuff.
converter is slipping bad should do 9.80/90 140ish once everything is sorted out on the 150.
Old 06-07-2009, 02:31 AM
Im guessing you got alot of weight out of the car??
Old 06-07-2009, 02:43 AM
lemons12's Avatar
its a drag car..
IIRC hes around 2900 lbs? i could be off though... car runs good.. i believe its like a 5k converter, but again could be wrong..
Old 06-07-2009, 04:29 PM
02ws602wrx's Avatar
well what about a 3200 stall and a ms3 with a dry 100 shot thats my dream and sending the converter out to get redone
Old 06-07-2009, 04:41 PM
FBGSU02's Avatar
i have the MS3 and i am debating on spraying 100 wet shot on it. I have herard that this cam loves nitrous.
Old 06-07-2009, 04:48 PM
kidcamaro98's Avatar
+1...thats what I want to do with my MS3 also.
Old 06-07-2009, 04:57 PM
01 Trans-Am WS6's Avatar
This is my plan aswell
Old 06-07-2009, 05:23 PM
lemons12's Avatar
i wouldnt go with a 3200 and an ms3 if it were me.. IMO thats way too small converter for that cam, or that cam is way too big for that converter, either way...
i would suggest something like a 3600..
Old 06-07-2009, 05:43 PM
Super Speed's Avatar
I'm not sure about the MS3 since I don't own it... but with mine on the 150 shot, traction is really hard to find on these nitto dr's... You definitely will need some Mickey's...
Old 06-07-2009, 05:48 PM
lemons12's Avatar
no doubt..
Old 06-07-2009, 05:58 PM
pozesd99''s Avatar
im putting my motor together as we speak.
its gonna be a full weight trans am.
complete street car.
lq9 bottom end with 241 which should make my motor higher compression than stock but also a 6liter.
so my guess is like 10.8:1 compression 364ci. i have a ms3 cam with ls7 lifters and plan on spraying a 200 on that sumabitch.
if it blows it blows.
im running a th400 with a 3500 stall and full drag suspension with slicks and skinnies.
i hope i can hit a bottom 11 all motor and maybe a low 10 on the juice
Old 06-07-2009, 07:38 PM
I think im gonna try the MS3 with a 100 shot.
Old 06-07-2009, 08:05 PM
camscam02's Avatar
Originally Posted by lemons12
its a drag car..
haha good try. it weighs 3360 though. heavy son of a gun.
dont really go by stall on a nitrous car. greg at FTI will be building the right converter for my setup here soon.
good luck boys.
Old 06-07-2009, 08:41 PM
lemons12's Avatar
good luck boys.
its been a while since i had seen your specs.. knew it was a bit radical but couldnt remember exactly what it had... was trying...
it does run good though... is 3360 race weight? if not, it runs damn good.. thats heavy..
Old 06-07-2009, 09:17 PM
Z28FirefighterI1's Avatar
The MS3 loves juice!!!! My race wieght is around 4000lbs running 10.60 @127 with a 315/35/17. That was spraying a 100 shot out the hole and a second 100 midtrack. I'll be ordering some 28" tires in the next week and see how much better I can do with a 150 out of the hole
Old 06-07-2009, 10:31 PM
That sounds like a pretty good set up you got there.
Old 06-08-2009, 02:13 PM
camscam02's Avatar
No, only 3360 raceweight, sorry to disappoint you. guess a cam and a 150 shot knocking on the 9's is just sub par for you.
go out and try to do it. it might not be so easy.
Quick Reply: Spray and an MS3
