New best N/A.....
Old 06-06-2009, 09:04 PM
ATVracr's Avatar
Default New best N/A.....
1.56 60'
6.75 @ 108.5 mph
10.37 @ 137.8 mph
Likes a little more timing and fuel... the new tune up seems to be working good. :drivin:
Old 06-06-2009, 09:13 PM
camscam02's Avatar
very nice. I saw you made some nice nitrous passes on the bullet in qualifying.
congrats
Old 06-06-2009, 09:25 PM
ATVracr's Avatar
We changed a few things and it should go as fast on 1 system as it did on both.
We'll get it figured out. ... Maybe
Old 06-07-2009, 09:29 AM
gator's 99TA's Avatar
real nice 60' with a nitrous tune up running n/a. i thought you guys liked low timing, but you are saying it liked more timing?
Old 06-07-2009, 11:16 AM
algws6's Avatar
good run!!
Old 06-07-2009, 02:10 PM
ATVracr's Avatar
Gator, it likes what it likes on motor(and yes it liked more). When we turn the N20 on lower than most is what we use.
Old 06-07-2009, 09:31 PM
ChevPower's Avatar
Nice, Sure wish my N20 setup would run on motor, My N/A best is a 10.50@129 but lately its only running 10.8@127 But it sure does shine with a little giggle juice
Old 06-08-2009, 06:24 AM
ShiznityZ28's Avatar
Last year it went like 11.5 @ 127 . We made some more power with carys intake and a 4 barrel up top but mainly it was just getting enough runs on the motor to find what it likes. the temp on the logger was 95 at the starting line so it will run better this fall. I also think theres another .1 in it with a few more runs to try some timming adjustments and a/f out. We only have 10 or so motor runs on it this year and mabe 8 last year. That will have ot wait until another test day when we don't hae anything better to do . Were going to mir to run a DR event thi friday so the bottles are comming with us.
Old 06-08-2009, 06:28 AM
Fireball's Avatar
congrats
was that on alpha-N or SD?
Old 06-08-2009, 08:02 AM
ATVracr's Avatar
Alpha-N
Old 06-08-2009, 08:08 AM
Fireball's Avatar
Originally Posted by ATVracr
Alpha-N
wow...didn't take you all that long to figure it out then
Old 06-08-2009, 08:40 AM
We had some advantages over just starting. I used all the log files from last times motor passes to see how much fuel we needed for a given rpm/tps Since thats one of the functions we log. Jeff Proc sent us Justin Smiths file as a start and it at least showed the curve we would need than I plugged our fuling from the logs in for idle and part throttle. We wanted to see how it would do on justins WOT stuff but it didn't like it and wayne lifted but it still went an ew best. 10.66 so I used that log to add roughtly 11% fuel on avg from 3-9K above 90% throttle and that got us close and we made timming and fuel adjustments from tere. so we got it down to 10.3 in 3 Alpha N runs.
The "Fast" makes it easy though and the logs are amazing in what you can figure out . I like to look at rate of rpm change and its a good indication if it likes things at certain RPM.
I wish we could get another 10-12 motor runs at a track rental.
Old 06-08-2009, 08:55 AM
Fireball's Avatar
if push comes to shove, there's always wednesday T&T at cecil, can probably get 5-6 runs if you get there early
you can get one t&t pass before MIR qualifying too.
Old 06-08-2009, 09:11 AM
Ill have to see if wayne wants to go to cecil and make some hits. well be at mir when the gates open ready to make a test pass thats for sure. Id really liek to be able to make the field at real street.
Old 06-08-2009, 09:24 AM
Fireball's Avatar
the real street field is gonna be very tough since its only 8 cars. I think the bump was a 5.6 2 wks ago.
rumor has it that lambert is testing and went 5.0 off the trailer then a 4.9 in testing and plans to be there friday...
At least theres the r/s eliminator too for Qualifiers 9-16
might be more than 16 cars on the property Friday
you know they let the R/S cars in before gates open...they'll let you in as early as noon. Plan on making at hit ~7PM...Q1 is at 8PM
Old 06-08-2009, 09:30 AM
Blackline13's Avatar
congrats!!!!!
Old 06-08-2009, 09:41 AM
Yeah. Whats the 2nd field been running? We could maybe get in the field but can't out run those guys in the top field....yet
Old 06-08-2009, 09:47 AM
Fireball's Avatar
there were only 14 cars
#8 5.72 (I was wrong about the bump)
#9 5.95
#14 6.98
Old 06-08-2009, 09:56 AM
We are only going to be on 1 kit if we can't get some test passes so we will be in the 5.7-5.9 range hopefully. we only been 6.0 on 1 kit so far.
Old 06-08-2009, 10:38 AM
FastBlackTA's Avatar
Thats flying N/A.
You guys are gonna roll this year!
