Full Throttle Timing Tuner settings...
Can I get some help or a good explaination on how to set the setting on timing tuner.
I want to set the window switch to activate N20 @ 4000 and turn off @ 6900
I also want to pull -6 degrees of timing during that same time.
What do I turn the ***** to
RTD
Base
WOT
RPM
Mode
Thanks I really don't understand the instructions very well.
Thansk in advance!!! Art
RTD
Base
WOT
RPM
Mode
They're actually pretty slick instructions once you get the hang of them. The settings are listed out on the chart...just select the switch from the top menu and follow that column down until you see the setting you want...For example, you want the nitrous on at 4K...look at the chart and find the RPM column, follow it down until you see 4K and look all the way to the left, that's the position you need to be in. In this case its the number 9. now the turn off setting, you need to follow the configuration steps.
With the key off, set the RPM dial to A, set SPARK BASE to 8, flip the MODE dip switches to OFF OFF OFF ON. Turn the key on, but do not start. Wait the ten seconds per the instructions (I believe there is still a glitch where both LED's won't light for 1 second, per the instructions). Once configured for the upper RPM, you can now set the rest of the switches as follows:
RTD - 6
Base - 0
WOT - 0
RPM - 9
Mode - OFF OFF OFF ON
Rick
RTD - 6
Base - 0
WOT - 0
RPM - 9
Rick
RTD
Base
WOT
RPM
Mode
RTD
Base
WOT
RPM
Mode
not to hijack, but i tried to reconfigure mine to a higher shut off rpm, and the instructions say that the red and green leds should light for 10sec. After i make the changes they both light for maybe 2sec. I have tried it several times. I havent sprayed it yet to know if it took. Is this normal??
Nick
awesome, i hope that is the only glitch. I dont like how i cant see the actual timing retard on my efi live log. I dont get any kr,a nd the a/f is good so i guess all you do is keep your fingers crossed that it is pulling the timing.
base, chart, full, instruction, instructions, instuctions, ls1, manual, nitrous, reconizing, settings, switch, throttle, timing, tuner, window
