Timing retard for a 100 or a 200 shot...
Have a 04 GTO 6 speed. It has a "forged 347" with a small cam and some 243 heads. I am wondering what kind of timing I should be looking at running on a 100 shot or a 200 shot through a brand x nozzle?
I will be running the non projected tr7 plugs, and all of the gas we have around here is 91 octane.
With my iat tricker, I will be able to have 2 different timing tables to choose from depending on how it is hooked up.
My timing na is around 27-28.
For the 100 shot should I pull 4?
For the 200 shot should I pull 8?
Or do I need to take more out to be safe?
Good luck, after weeks of searching, I came up with nobody knows. For example, I have a 400hp stock motor with 22-23 degrees. I heard for every 50 to pull 2 degrees. This would put me at 18 on a 100 shot. If my research is correct. Stock timing is 26 and plenty people run 100 shots on stock timing.
Every car is different. Too many variables to answer that question.
For example... On a 150 I have 12 pulled and on 200 I will probably end up with 2 more pulled.
this makes my head spin. i think ill just take it to the tuner for the first spray on the dyno so we can watch afr and check plugs and make adjustments as necessary. seems like the right thing to do.
As said every combo is different, even exact same setups might take different tables. I've seen People run up to 150 shot on stock timing, then again I have seen motors pop with a 100 shot at stock timing..As Nitrous goes up add an additonal 1-2 degrees for a safety factor. I.E. say you take 2 degrees out for every 50 then at a 200 shot instead of taking out 8 degrees take out 10-12 and start from there. It is best to "Read" the plugs after every pull on a large shot..we do
Well maybe I should pull 6 for the 100 shot and 12 for the 200. This would put me at about 22 on the 100 and 16 on the 200.
This isn't a dual stage. It is either a 100 or a 200.
And remember. 91 octane.
get your n/a tune running strong first, forget about the 200 for now, just start with a 75w and see where your afr is first. once you get the aft around 12.0, then you will know if takes one or two fuel jet sizes to get to 12.afr. follow the same pattern with the 100w with a new set of plugs and ck. them after the first run, if youre timing mark is where it needs to be, cut the plug and see if you want to go leaner. the 200 on 91oct is a risky plan on stock compression, i would not run it until i'm sure the 100 is optimal. do you know your compression?
