Rwhp loss.
Remember, when using another companies jet charts you have to consider what bottle pressure they are rating at, it's not all apples to apples. Either use ZEX jetting and bottle pressure, or use NX jetting and bottle pressure. Off hand I don't remember what pressure the Zex stuff is spec'd at, but the NX stuff, IIRC, is like 1050psi. You didn't state your psi on the bottle, is it low by chance? Also, you really should be verifing the a/f ratio if your going outside the companies jetting, well, we should be even when using the ZEX specs for safety.
Robert
Robert
