converting dry to wet.
Old 06-21-2009, 01:51 PM
johnLs1camaro's Avatar
Default converting dry to wet.
I am wanting to convert my dynotune dry nitrous kit to wet. I am really wanting to know all of the parts I would need to do this. I understand they sell a dry to wet conversion for $175, but im thinking a could by the parts seperate from people and come out cheaper.
Thanks for any help you can give.
Old 06-21-2009, 03:13 PM
SkullV's Avatar
Fuel solenoid, line for fuel rail to solenoid and line for solenoid to plate. Fuel jets, various wiring.
Old 06-21-2009, 03:40 PM
wouldnt i just use the the wiring it came with and connect it to my relay switch where my nitrous selenoid is hooked to?
also isnt there a y where the nitrous and fuel enter as one and spray into the engine?
Old 06-21-2009, 04:39 PM
SkullV's Avatar
I'm not 100% sure on the wiring, but you will need a nozzle unless you already have a 2 inlet plate kit.
Old 06-21-2009, 04:53 PM
RsSean's Avatar
Do you have a window switch? If you do you can just splice in the power and ground off your new fuel noid to your nitours noid. Buy the nozzle that taps into your bellow, then the an4 fuel line and you are good to go.
Old 06-21-2009, 04:58 PM
yeah man i have the hsw microedge, so can i do it that way?
Quick Reply: converting dry to wet.
