Help with nitrous not spraying
First off it is a Dyno tune LS1 kit. I have the single stage window switch hooked up to it as well. This system worked fine the few times I used it last year. Was not used at all this past winter and part of the spring. I did take part of it off in installing my headers a few months ago. Since then I hooked it all back up, and went to test it by holding the fuel line out and away and have the window switch engaged to spray fuel to the ground.( I did that last time, don't need the fuel to not work but the nitrous does lol) I checked the solenoids first with the purge, it works it sprays correctly. I then undid the positive wires for the noids and ran them over the + terminal of my battery they both click.
Well everything seemed fine but it will not spray at all. When I have the car on and rev it to the desired window parameters I see the switch is working and reads off that it is functioning, but nothing happens. I know last year I had an issue with the 30 amp relay so I bought a new one and that fixed my issue, now I did that again this year, and it won't work. I have checked the wiring and like I said the solenoids click and when I ran the fuel solenoid + wire on the battery, and was checking the line to the nozzle it was wet from fuel but when trying to set it through the system, nothing happens. Any ideas?
It is. But I know that the instructions from dynotune advise doing so, because the of the readout the tach signal from ls1 pcms tend to do mimic a 4 cylinder car. I'll give that a try and see what happens later on today.
I found the problem. I need to take better mental notes when undoing my kit. So basically 2 negs won't power anything lol. I thought I had 2 + lines but could not remember for sure. Now I know I do lol. So yeah issue fixed.
